Key blanks
peer oliver schmidt
1,261
My 23' only has one set of keys. Anyone know where I might find key
blanks for the ignition and the door key?
Best regards
Peer Oliver Schmidt
PGP Key ID: 0x83E1C2EA
'76a Eleganza II 26', VA
'73 Sequoia 23', Germany, SH
The keys are common used by GM for about 40+ years in all their products. On this side of the Atlantic just about every hardware and automotive store
has those blanks and can duplicate you a key. A Locksmith is a better place to go as their equipment is more accurate and they know what they are
doing, the copies will work everytime. Hardware store copies may be a little finicky to use.
Bruce Hislop
ON Canada
Hubler 1 ton front end
The original "GM" key blanks are still available. In this era here are 8 different key series that vary by model year and whether the lock is
ignition or door / trunk / glovebox. They will be common with other GM vehicles and the series is identified by an alphabet letter stamped on the
side of the blank;
'73 ignition - "E"
'73 door - "H"
'74 ignition - "J"
'74 door - "K"
'75 igntion - "A"
'75 door - "B"
'76 ignition - "C"
'76 door - "D"
'77 ignition - "E"
'77 door - "H"
'78 ignition - "J"
'78 door - "K"
If your locks have ever been changed all bets are off. Also I have seen a few transmode coaches titled later than the chassis i.e. a "78 Royale"
based on a '77 chassis. The VIN defines chassis year "TZE16XV100001" where the "X" is the model year.
One last tip - take good clear digital pictures of your keys. A good locksmith can make duplicates from photos.
Chris Geils - Twin Cities
1978 26' Kingsley w/ very few mods; Headers, Progressive Dynamics 9040, aux trans cooler, one repaint in stock colors, R134a, Al rad, 50k mi
I've had no problem going to locksmiths in the Seattle area and having good duplicates made. I'd avoid places like Home Depot. The actual locksmiths
know what they're doing.
Brian K
1977 Eleganza II, TZE167V100261
Bellevue, WA
Rebuilt 455, New brake system, a lot of Original Equipment ready to fall apart (discovering more as I go along....)
