> I appreciate all your help. Do you think that I could possibly modify the
> Jeep system to fit on a Quadrajet sized opening?
> Emery Stora
> Their last reply:
> No, the mounting stud for the jeep is off center and to the left and the
> heat shield would be useless on another vehicle. The tube may be too long
> or go to an inappropriate spot on your motorhome. Sorry.
I do know that the air cleaner on my 96 Impala, for which K&N makes an
element, is a remote box with ducting to the air meter. I also know that
there are aftermarket suppliers making "high performance" variants of this
air cleaner, so I would think that if a suitable fitting to adapt the hose
to the carburetor's air horn could be found, an air cleaner would not be a
big problem.
Travis
> Emery Stora
> Their last reply:
big problem.
Travis
