> Ok that is a slightly different symptom description than the original. You need an accumulator, but we knew that. That should fix it.
John,
Ya, it actually does both...
The motor runs about every 5 seconds or so for about 2 seconds....when no foot on brake mostly after driving for a while. When I first hit the switch
in the morning, it will run for 6 seconds or so to charge it, and not run then until down the road. And it does run with continuous pedal apply about
once per second for a second, like when at a stop sign. Only takes one apply to run motor. Runs every time I apply pedal pressure.
So, thanks for the advice. I'll be getting the one from Kirbanperformance. Anything else you can think of while I'm working it?
Larry
78 Royale w/500 Caddy
Menomonie, WI.
