I have followed with interest his comments about why carbs no longer work (=
todays gas won=E2=80=99t vaporize correctly for use in a carb) and now why =
our engines are blowing up mote frequently (they run too hot under some con=
dition). Take a look at the presentation I did on Fitech (http://www=
.bdub.net/FiTech_is_the_Real_Deal.pdf). Near the end are two important sli=
des that I think help explain what he is saying. The slide with the two ch=
arts is very telling. Those charts are based on an engine running pure gas=
oline with a stoichiometric air/fuel ratio of 14.7:1. One chart shows peak=
power at an air fuel ratio of around 12.5:1 (quite rich) while peak econom=
y is around 16:1 (way too lean for our engines to survive for very long). =
Those charts are based on UNADULTERATED gasoline. The curves for gasoline =
laced with alcohol would look much differently. The slide on the nex=
t page shows stoichiometric A/F ratios for various chemical compounds. For=
octane it is 15:1, for ethanol it is 9:1. We not only have been adding et=
hanol, we have also added a number of other distillates and removed others.=
So, just as he has been saying, everything we learned about engines when =
we were all much younger is out the window given whatever it is we now pump=
into our fuel tanks. Just for giggles, see what happens to those curves i=
f the only change was adding 10% alcohol. The stoichiometric would shift f=
rom 14.7 to 14.1. Now guess what happens if you go to lean, either because=
you reprogram your fuel injection to do that, or because your carb gets di=
rty inside and does it on its own without you even knowing it, or because y=
ou monkey around with the jets, air correctors, power valve springs, etc. i=
n the hope of better mileage. On flat land you might get away with that if=
you drive at 50 to 60 mph where the air drag is low, but climb any kind of=
hill or load the engine up with head wind or by speeding up and you will q=
uickly be running way too lean for the conditions and way to hot for any ki=
nd of engine longevity. Just what he has been saying. I am not a petr=
oleum engineer so don=E2=80=99t know for sure how those curves change shape=
for whatever is in our fuel today, but my guess is however those curves ch=
ange the result is we should now be striving to burn MORE FUEL day in and d=
ay out if we want to keep these old engines healthy. I=E2=80=99m going to =
guess there is a direct correlation between fuel consumption and engine lif=
e. Likely 8mpg is around the BEST one should shoot for these days. =
How many times have we heard people say that their coaches ran much better =
and got much better fuel economy driving in Canada on premium fuel with no =
alcohol. The only way that could happen is if that coach was set up way to=
o lean for driving on gasoline laced with alcohol. My thoughts anyway. =
Jerry Jerry Work The Dovetail Joint Fine furniture designed and=
hand crafted in the 1907 former Masonic Temple building in historic Kerby,=
OR glwork http://jerrywork.com =
