Jasper Engines at Fleet price
thomas g. warner
1,863
Just learned that another netter took advantage of our agreement with
Jasper, and got a 455 remanufactured long block for $2834 delivered to
Florida. That makes two this week. hope that more take advantage of it if
they need an engine. I would keep this e-mail for your later use and maybe
patrick could even put it on his site.Notice that there has been a price
increase of $400, however the warranty has been increased to 75,000 miles.
Our contact point there is Dameon at 1-800-827-7455,extension 3750. He is
giving us the National Fleet price. Just mention my name and this message to
get the price.
Anone think there is a need for transmissions and heads. they have a similar
warranty.
Per your request the following information applies:
This engine is going to be remanufactured back to or exceeding
O.E.M.specifications. It will consist of the remanufactured block, heads,
cam, crank, and rods. It has a standard set of new internal parts that include:
pistons, rings,bearings, lifters, valves, valve springs, and timing components.
Included with the engine will be the oil pump, oil pan, and the timing
cover. These are
already installed on the engine for you.
After the engine is built-up, we then LIVE RUN TEST it at the
factory to make sure that it is going to be running properly when you
receive it. We
actually pour the fluids in and run it for 1/2 hour to 45 minutes. While it
is running we
run checks on oil pressure, vacuum, and compression. We also check it for
any leaks
or noises. This JASPER complete engine will be backed with a 3 YEAR /
50,000 MILE
WARRANTY. This warranty covers PARTS AND LABOR and is good NATIONWIDE.
The price on your 1974 GMC Motorhome 455cid carb engine is $2434.00 exchange.
If you would like to get this engine on order, or if you have any further
questions
please call my sales department at 1-800-827-7455. Thank you
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
"The beautiful Mohawk Vally"
