I like the "Up Scotch Creek without a paddle" word play...
The standard to get the coach up safely to change tires is logically a lower standard than to leave the coach for an extended period that includes you
actually being under it. The temptation is to "just take a look at X..." Don't do it - especially on an unknown coach!
You asked for clarification on jacking the rear in such a way to then put something under the bogies...the frame around the rear wheels area looks
plenty solid from the curb view of it - it is not strong enough to jack directly on the frame, or put a single jack stand under it. If you distribute
some weight it does fine - that's why I said I use a 4x4 (at least two feet long) between my 3 ton jack and the frame. There are cross members every
four feet or so that go side to side
Here are some pics of a frame by itself
http://www.gmcmotorhomemarketplace.com/stuckey/
Ideally, you want to catch one of these "T"s in the frame, with a distributing block on your jack. Lift only enough to take the weight, reduce air bag
pressure to not overextend the shocks, then continue lifting enough to then place stout wood blocks under the bogie.
Alternately, you can jack under the bogie directly, and then crib up the frame for safety.
Raleigh, NC
Raleigh, NC
