Jack Hodgman - BC, Canada
emerystora
14,608
2
1
Jack -- I tried to return a message to you by e-mail direct outside
of the GMCnet and it kept being returned. I tried "Jack
Hodgman"@bc.sympatico.ca, Jack Hodgman and Jack
Hodgman @bc.sympatico.ca but none seemed to work.
Get back to me and I'll try again.
Emery Stora
77 Kingsley
Santa Fe, NM
FYI, white space is illegal in an e-mail address, and hence that is why any
attempt to send to "Jack Hodgman" will fail. This will attempt to
mail to "Jack" and "Hodgman", and not the user that you attempted to
send to.
- - Tim
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
Tim Dawson (tadawson) Owner/Engineer
TPC Services Bellnet: (972)-221-7385
Lewisville, Texas 75067 FAXnet: (972)-221-0393
"The world is complex. Sendmail.cf reflects this...."
>send to.
>- Tim
Thanks Tim. That's why I tried to send it three ways. This is what
the message from him had as the address:
Notice that it has the quotes around the name and there is a space in the name.
Any other suggestions?
Emery
> From: Jack Hodgman
name.
> Emery
Try using the upper case dash _ between the first and last names. I've seen
this cause your problem because the underlining that Explorer puts under the
entire address disguises it.
Give it a try.
Travis
Travis,
For whatever reason my E-Mail will not accept capital letters in the
address. I learned that when I had to change Majordomo to majordomo.
HTH
Bob Schoner
To:
Sent: Sunday, May 28, 2000 9:32 PM
Subject: Re: GMC: Jack Hodgman - BC, Canada
> From: Jack Hodgman
name.
> Emery
Give it a try.
Travis
Per the internet RFCs, e-mail address is case insensitive (IE does not matter)
so there is no need to ever use uppercase, unless you really want to . . . .
- - Tim
[Charset iso-8859-1 unsupported, filtering to ASCII...]
> Travis,
> HTH
> Bob Schoner
> From: "Travis Martin"
> To:
> > From: Jack Hodgman
> name.
> > Emery
> Give it a try.
> Travis
On a lot of PCs, the user types in the reply-to address, and it is not derived
by the system. Hence, I suspect that Jack put an invalid reply-to address in
his mailer, and hence is deaf to replies. You may want to look at the headers
on the mail (detail view in Windows mailers?) and see if you can spot any other
variant.
- - Tim
> >send to.
> >- Tim
> From: Jack Hodgman
> Emery
