Great,,,
looked like mine except the different wire was the alternator.
gene
>Gee I guess if I am going to put color pictures up I will
>have to correctly color code the wires on the unit. You are
>correct about the center terminal being alternator. The
>yellow wire goes to a battery. I got 50 20' rolls of 10
>gauge yellow wire from work for free when Accel (yes the
>racing stuff) bought Mr Gasket about 5 years ago, I work
>for the parent company.
>Date: Wed, 19 Jul 2000 11:33:14 -0700
>From: gene
>Subject: Re: GMC: Warner Puller
>Hi
>I just looked at your battery section on your web page and
>it is=20
>strange
>but it looks like your diode isolator is not connected
>correctly ????
>Normally the two outside connections are to the batteries
>and the=20
>center
>is to the alternator. Is your Isolator different ??
>gene
>>I have a Warner puller and have used it. I added a small
>>relief area to the ring and made the threaded puller
>>portion myself. I have access to a full machine shop and
>as
>>far as I am concerned the ring portion made and designed
>>for me is worth the $200. Ever try to get a bearing like
>>that off without a ring as supplied with the Warner
>puller?
>>I have. you end up using a cutting wheel to cut the inner
>>race and chiseling the broken inner race off. Anyone
>>reading the net for a while knows that Tom can be a bit
>>sharp with his responses but he has done the GMC
>>community a service by providing this tool. As was
>>mentioned if the inner race has spun on the hub it can
>make
>>removal problematic at best. There is a picture of a
>>dammaged hub on my site listed below. If your hub looks
>>like this you need a new one, I had a great time getting
>>the old bearing off the hub shown there.
>> 3D 3D 3D 3D 3D
>>Alan Bredbury
>>Clinton, Ct.
>>1974 GMC 26' Classic Motorhome
http://www.finesttool.com/index.html/special.htm
>>__________________________________________________
>>Do You Yahoo!?
>>Get Yahoo! Mail 96 Free email you can access from
>anywhere!
http://mail.yahoo.com/
>Alan Bredbury
>Clinton, Ct.
>Do You Yahoo!?
>Get Yahoo! Mail =96 Free email you can access from anywhere!
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
