Isolation switch install
boybach
1,033
195
63
I already installed an isolation switch up front on my chassis battery system and today I started doing the same thing to the house battery.
My house battery is located in the battery compartment next to the Onan. My plan was to install the switch into the negative side.
As I was marking out the bolt positions for the shut-off isolation switch I realized there are TWO negative lines attached to the battery, guessing
the one leading away must be the line that connects to the systems up forward while the other runs to a ground bolt close to the battery.
Even as an electrical ignoramus it seems to me that installing the switch into the ground connection line close to the battery is not going to shut
off the battery completely as the other negative line would apparently still be able to connect to ground, right?
So do I have to run both negative cables to the switch to shut down the house system?
Larry
Larry - Victoria BC -
1977 Palm Beach 40,000 miles, PO said everything working but forgot the word NOT. New Atwood fridge, water heater & furnace. New SS exhaust system,
6000w Onan, Iota Converter, R134A A/C, New fuel lines & heat exchange hoses
Yes. All wires off the ground side
Sully
Bellevue wa.
> house system?
> Larry
Sully
Bellevue wa.
Thanks! Made sense but I thought I'd better check with the forum.
Job for tomorrow.
Larry
It makes no difference which side (+ or -) you put the disconnect switch and long as the battery is completely disconnected on one side in the end.
My switches (engine and house) are both on the plus side.
That disconnect switch saved my coach from burning to the ground about 15 years ago. It is a long story. Place those switches where you can easily
and quickly get to them in case of a fire or other emergency. Mine was a gasoline fire fed by a shorted and stuck on electric fuel pump.
