Isolater vs Alternator
May 4, 2007
150
16
I replaced my 80A alternator with a 100A with dual belt pulley.
In getting the transmission replaced the coach was unplugged and static
for 1.5 months 450 miles from home. During the return trip the 2x12V
house batteries fully loaded the alternator (supposition to fit the fact)
and the 100A alternator toasted the isolater. I know the exact moment as
the dash blower was on high and the blower hit warp drive 9+. Blue smoke
came from the dash and nasty electrical stench. (We were in wall to wall
traffic and could not pull off.) Bypassed the isolater at a pull off so
we had power.
Replaced the house batteries with a 4D deep cycle, replaced the blower motor/fan
assembly, tossed the isolater and now rely on combiner. The blower hi speed gets
its power straight off the alternator tap to the isolater. When the isolater failed
due to overload the sense circuit maxed the alternator.
1977 Eleganza II
Ogden NY
Your problem was the unplugged alternator. By unplugging it, the alternator lost it's reference voltage and went to maximum which was 18.5 volts or
more depending on the regulator version built in the alternator. You are lucky if all you lost was the isolator. The same thing would have happened
if you had a combiner installed. The excess voltage and associated current caused by the disconnected alternator sense line had to go somewhere.
Usually it is the battery(s) that most of absorb it until they boil dry. Then the voltage goes even higher.
I had that happen on an airplane that I was flying one time. It boiled the battery dry and then took out the radios and several position lights. I
ended up shutting down the alternator in flight and flying home a couple hundred miles in the dark without anything electric working. Aircraft
engines do not use any alternator / battery electric to run. They have dual magneto ignition systems.
Sounds like the isolator to the chassis battery opened which increased the
alt. output and cooked the house batteries. If the house battery load had
been the problem the other side of the isolator would have opened and the
house battery would have been saved.
Looks like you we should oversize the isolator. We should be able to build
our own isolators from diodes.
Correct me if I am wrong but I think we could use half of a full wave
bridge like:
https://www.amazon.com/Baomain-Bridge-Rectifier-MDQ-100A-Module/dp/B01JIKSHCA/ref=pd_sim_328_3?_encoding=UTF8&psc=1&refRID=AS5H1C1VNSSMRHE2WHZZ
or
https://www.amazon.com/Baomain-Bridge-Rectifier-MDQ-200A-Module/dp/B01JILFZCO/ref=pd_bxgy_328_2?_encoding=UTF8&psc=1&refRID=7VY1G9T5A8A558NREZJJ
> volts or
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
*John Phillips*
John,
That would certainly work if you use the two ac terminals as the two
battery terminals and the (-) terminal for the alternator input. That
would provide the necessary isolation of the batteries. At the (+)
terminal would appear the highest of the House and Chassis battery
voltages, less about 0.7 VDC. For those using electric windshield wipers,
that could be used as the +12 VDC supply, providing a speed reduction of
about 5%, which many would like. Or it could be used for any accessory for
which constant supply from either battery was desired (radio?).
The BIG question is whether the bridge, despite its rating, would survive
for very long. Certainly it should be mounted to the aluminum plate, or,
preferably, a finned heat sink, with thermal paste. I would NOT use the
100A version. Since they're designed for ac rectification, the average
current through each pair of diodes is only 1/2 of the bridge's rating.
Longevity may still be an issue.
Without knowing the internal construction of the bridge, it's difficult to
evaluate its probable longevity, but I suspect it's not as robust as the
isolators. Those have two diodes with their metal cases bonded to a common
aluminum plate to which the alternator input is connected; the other ends
of the diodes connect to the batteries. That assembly is potted with an
epoxy for environmental protection. I've never yet seen nor heard of a
shorted isolator. They predominantly fail by becoming open. I've cut,
broken, ground away the epoxy on a couple of failed ones and found the
"failed" diode (still good) separated from the aluminum plate. My theory
is that the different thermal coefficients of expansion of the diodes,
aluminum, and epoxy stresses the diode-plate junction, causing it to
eventually fail. Isolators are designed for the continually varying
current and environmental conditions to which we subject them, yet they
eventually fail -- too frequently.
I suspect that the subject bridges are intended for use in primarily
constant loads and may be more likely to fail in our application.
Thus, I prefer a robust combiner, which totally eliminates it as the cause
of the loss of feedback condition which causes runaway alternators. I have
had 2 of the Yandina C100 combiners fail. After one replacement under
warranty, the second time I upgraded (with warranty credit) to the C135,
which has given no trouble for 5+ years. It should be remembered that
Anna-Marie Foster, Yandina, inventor of the combiner, originally rated the
C-100 at 50A. Competitors offering almost identical units with 100A
ratings forced her to change her specification -- with no design change. I
consider the original 50A rating more appropriate.
Americus, GA
www.gmcwipersetc.com
On Sat, Dec 2, 2017 at 5:10 AM, John Phillips
> bridge like:
> or
> or more depending on the regulator version built in the alternator. You are lucky if all you lost was the isolator. The same thing would have
> happened if you had a combiner installed. The excess voltage and associated current caused by the disconnected alternator sense line had to go
> somewhere. Usually it is the battery(s) that most of absorb it until they boil dry. Then the voltage goes even higher.
> I ended up shutting down the alternator in flight and flying home a couple hundred miles in the dark without anything electric working. Aircraft
The question that comes to my mind is there a way to protect against the sense circuit failure?
Or is vigilance your best defense?
Tom Lins
Elkton, FL
77 GM Rear Twin
Tom,
WIth the installation of a combiner, the chassis battery is always
connected to the voltage sense line to the alternator, thus eliminating one
of the two most common causes of sense circuit failure. The second, much
less common, failure, the connection at the alternator, can only be managed
by rare preventative maintenance: Disconnect and examine the connector,
replacing it if corroded or weak, and applying some contact
cleaner/lubricant, such as CRC 2-26. Gene Fisher's APC (Alternator
Protection Cable) offers new, good quality, connectors so its installation
should help, despite the addition of one more pair (Pins 1 & 2) of
connections. The Nichrome wire protection is not the only benefit of the
APC! :-)
​PS: Tom, I just noticed your signature block: "Elkton, FL". When did
you move? Or are you playing Snowbird? Will we get to see you at the
​January GMCSS/GMCDL rally in St. Augustine? KH
That is WHY aircraft have dual magnetos.
Some alternator regulators have a limit built in to them. I think it is set around 18 volts. On my airplane after I fixed the damage and replaced
the external regulator, I added a crowbar circuit that fires an SCR and trips the field circuit breaker at around 15 volts. That shuts down the
alternator. This would not work on a GMC because the regulator is internal to the alternator.
On a GMC I have often thought of adding 2 diodes in series giving a 1.3 or 1.4 volt drop. The diodes could go between output and the sense line
input. Also 2 resistors could be used between the output and ground. Then tap the junction of the two and attach it to the sense line. The values
could be 9 to 1 or 15 to 1 for a 10% to 15% voltage cap.
On the loose sense connection at the alternator. On mine the connection that was loose was actually on the added APC female terminal. So I am
suggesting that even if you have an APC attached, that connection needs to be checked to be sure it is very very tight. That APC was on there for
many years before the connection failed. I really felt stupid when I found it, because Colonel Ken had already twice run be back and forth to AZ for
a replacement alternator.
When this problem popped up, I noticed it on my $2.00 volt meter while driving. I was able to manage the over voltage while driving buy adding load.
I turned on the headlights and ran the heater fan at various speeds to keep the output at a reasonable voltage level. When I arrived at the rally a
couple of days later I erroneously replaced the alternator under warranty and eventually found the loose sense connection. Without that meter I would
not have been able to accomplish this.
But Ken —
Even with an isolator "the chassis battery is always connected to the voltage sense line to the alternator”.
I would think that if you have a combiner then the voltage sense line is connected to both the chassis battery and the house battery which would then “hide” a weak chassis battery from the alternator.
Am I not correct on this?
Frederick, CO
> Tom,
> APC! :-)
> Ken H.
Emery,
Wben installing the combiner, the chassis battery should be connected
directly to the sense wire. Since the combiner only closes when it senses
charge-capable voltage (~13.8 VDC), the sense line would not be connected
to the house battery if the alternator was too weak to achieve that
voltage. So, no, the combiner would not "hide" a weak chassis battery.
Can't necessarily say the same about a house battery though: There is a
condition in which the combiner could be detrimental: A defective house
battery could pull the alternator below charge voltage while the combiner
was closed, even with the sense line attempting to hold the voltage up.
The combiner would drop out after a preset delay (30 sec., IIRC). With the
excess load removed, the alternator would again achieve charge voltage,
closing the combiner, and again attempting to charge the weak battery. So,
the combiner could conceivable subject the alternator to cyclic full
loading and even over-stress.
Seems like there ain't nuthin' perfect!
> But Ken —
Most passenger cars used one-wire alternators, where the output voltage is
sensed internally. We used to convert Delco three-wire alternators to
one-wire alternators by wiring the field-sense wire to the exciter wire
(which is connected to the battery). I built a rally car out of a Toyota
Corolla back in the day, and the three sets of driving lights were too much
for the 40-amp Toyota alternator. I replaced it with a Delcotron modified
to tie the sense wire to the exciter wire right at the plug.
With a combiner, I don't see why we couldn't do that now--no isolator diode
drop requiring compensation. That would reduce the failure point to the
plug itself.
Rick "thinking out loud" Denney
> Tom,
> APC! :-)
> Ken H.
Rick Denney
73 x-Glacier 230 "Jaws"
K.I.S.S. is a principle that guides a philosophical mindset. Mine in
particular. While combiners may the best thing since sliced bread, they
still complicate an otherwise anvil simple system. Not much to an
alternator, a trio of conductors, and an diode isolator. Darn thing either
works, or not. Combiners, with their combinations of wires that MUST NEVER
be shortened, along with led lights that sometimes are steady, sometimes
blinking like Rudolph's nose, sometimes not at all, are a bit like
redundant components that only create more questions of their own. I will
stick with what I know.
78 GMC ROYALE 403
> Emery,
> Ken H.
> > But Ken —
The isolater failed; dropping the sense circuit. The alternator ran away, leaving the dash blower as the only load on high. When I stopped I moved
the alternator output direct to battery on the isolater giving the alternator load and sense.
1977 Eleganza II
Ogden NY
The sense wire to the alternator does not connect to the isolator. It goes to the engine battery through the wiring harness. If the isolator failed it shouldn’t drop the sense circuit. When your isolator failed it didn’t allow the alternator to direct the right voltage to the engine battery which caused the sense wire to the alternator to increase the voltage from the voltage regulator.
When you moved the alternator output direct to the battery it then gave proper voltage to the battery and the sense wire that told the alternator voltage regulator to drop the voltage to the normal amount.
The alternator wire you moved doesn’t include the sense wire — just the alternator charging output.
Frederick, CO
> 1977 Eleganza II
> Ogden NY
Sense wire on the engine battery terminal of the isolator -- is the engine battery as Emery said. Someone above asked how to prevent the problem.
Don't run a 100A alternator into an 80A old isolator. I would want at least a 150A. They are not expensive. I run the Yandina combiner across the 2
battery systems at the isolator. Works great an don't have to think sbout it.
I see one other "problem" with ditching the isolator. A bad alternator cannot draw down batteries if the isolator is in place as current can't flow
that way.
Wow. Doom and gloom on isolators.
My OEM isolator and my 100 amp dual pulley alternator have co-existed for 13 years. I put a lot of load on them as I seldom plug in anywhere when I
travel. So during the day my alternator and isolator have to recover the discharged golf cart batteries.
I have been involved with the replacement of 3 combiners and 1 isolator on GMCs. None of which were on my coach. The isolator that broke was rusted
so badly that I twisted off a stud trying to loosen the rusted nut. Had I left it alone and not tried to clean the connections it probably would
still be running today. I have the bad isolator and someday I'll open it up to see if the stud can be replaced. It was and is still good
electrically. That is more than I can say about the three bad combiners I worked on. Two of the bad combiners were on Dan's coach. He ended up
carrying a spare in case it failed again.
Ken,
It appears that Yandina no longer makes the C-135:
http://www.yandina.com/
Keeping in mind that I am electrically challenged would the C-160 be the one to order?
The Pedantic Mechanic
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Ken Henderson
Sent: Saturday, December 2, 2017 6:52 AM
To: GMC Mail List
Subject: Re: [GMCnet] Isolater vs Alternator
John,
Americus, GA
> bridge like:
> or
Yes. IIRC, the C-160 uses a large external solenoid relay rather than the
internal one in my C-135.
> Ken,
> one to order?
I don't know about all the other versions, but I have a 73 that has some traits that lead me to believe it was a strange build. The alternator is
supposed to be 80amp. The machine in that place now (I did not replace it, but it has been serviced) still looks like the 80amp version. But, things
have probably been changed.
We were having alternator belt trouble early on. It was so bad that I regularly put on two belts and tied one back because on a '73 the fan blade and
the A/C belt both have to come off to get the new belt in where it needs to be. It was not alignment and I could still but a belt with the right back
width. But I was not yet on the forum. This went on for too long because I always though I had a fix in. When I was trying to figure out why I was
losing belts (yes Gene, they were at specified tension) whenever we dry camped, I finally put my Hall Probe on the alternator cable one morning. I
was really expecting to see that the charge profile was wrong (too high a current for too long). Well, even though the machine is supposed to limit
at 80, after the cold start and during the time at high idle, that Hall probe, and Fluke 87 set told me that they were witnessing 96 Amperes....
Before you say that can't happen, remember that when this coach was built it was supposed to have an E5000 91R (Grp.27 side terminal) house battery in
the right front. That is a roughly 80AH battery. It was at that end of a piece of #10SAE (not AWG) wire. That battery was a 4D when I got the coach
and the #10SAE is now #8 (maybe 6) AWG. This makes for a condition that is very different than when what the pictures and old numbers would allow.
That was when I hunted up a dual sheave for that service. Yes, the power steering sheave can slip when very wet, but it is very manageable when it
does.
While doing all the boat work I did before the depression shut us down, I was both informed by suppliers and gained some first hand experience (at my
own cost) that a 100 Ampere load on a 12V nominal machine is about all any single V-belt can do for very long at all. There are available marine
service machine and regulator sets that can be programed to limit the output current. I have installed these, but the cost is a serious issue. They
are great for sailboats where upgrading the installed alternator drive is impractical.
Now, what really surprises me, and I am not complaining, is that it seems that the isolator has never been replaced and still functions as it should.
I did replace a very few isolators, but I also replaced more than an few Yandina Combiners. Those were both the 50 and 100 size. The contacts would
cease to make a solid an dependable connection. Those are the little ones that come with wire leads that you are not supposed to shorten because just
like the #10 battery wires in a GMC, those are a current limiter. The larger version Yandinas all have lugs. I saw those very rarely and never had
to replace one.
We now have a dual sheave and a pair of GC2s and I put a PD9260 up front to get the house charged when I have to do it with the APU.
Ken,
I clicked on the C-160 and this link opened:
http://www.yandina.com/c160Info.htm
It doesn't say anything about a large external relay?
Sydney, Australia
Sent: Sunday, December 3, 2017 8:57 AM
To: GMC Mail List
Yes. IIRC, the C-160 uses a large external solenoid relay rather than the internal one in my C-135.
