We just got back from a trip to the New Mexico’s mountains with some pretty steep grades. So I wanted my brakes to be in tiptop shape. First of all,
I’m a one man show when it comes to working on my coach. And I’m not that good of a mechanic. Previously Ive tried to gravity bleed and peddle
bleed, not the greatest of results. So I bought one of Jim’s bleeder kits. First of all, everything you need is included except the brake fluid.
What impressed me the most was the workmanship that went into the reservoir top plate. The pressure bleeder is very easy to operate, great for a one
man operation. Just fill the pump with brake fluid, pump up to the correct pressure, get out the manual for the bleed order, and bleed. EASY!!
At the same time I changed my fluid from Dot 3 to Dot 5.1. Just suck the old fluid out of the reservoir with a turkey baster and flush with the brake
bleeder/flusher kit.
This kit should also work with any of your old classic cars also.
Needless to say, I now have great stopping brakes, or as good as can be in these motorhomes! Descending the grades in the mountains with a heavy coach
and a towed Tracker was not even a issue. I think this kit was definitely worth the price. Everyone or every club should have one. BRAKES ARE
IMPORTANT.........
Thanks Jim!!
Scott.
Scott Nutter
1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21 final drive, Quad bags, tankless water heater, everything Lenzi. Alex Ferrera
installed MSD Atomic EFI
Houston, Texas
IMPORTANT.........
Thanks Jim!!
Scott.
Scott Nutter
Houston, Texas
