Is the rear window gasket/seal generally good to uses for the replacement glass?
I have had good luck reusing them. Just clean real good and use glass cleaner for lube to reinstall. Tire soap also works well. You will need a
tool for putting in the lock strip but it's not expensive. Rope method works well or you can work it in with plastic glass knives.
> The original window was the victim of a pellet gun. Bob Dunahugh
C. Boyd
76 Crestmont
East Tennessee
Chuck, Thanks for the help today. I got a call back and they said they had it working and that you were a big help.
Thanks Charles for your conformation on the gasket. The only gaskets like that. That I've had issues with were from Arizona. Plus I have zero experience with the GMC rear window.
Bob Dunahugh
