Inverters / single function
mr.c
494
It was easy for me to put in my inverter and to run a line to the power
control box and to find the two outlets I needed to have with 120 v. The
rest were left as original. I think it has worked for me without having
lots of inverters to connect up.
my .02c
Al Chernoff
> -- [ From: Eugene Fisher * EMC.Ver #2.5.3 ] --
> I would like to suggest another plan for providing battery powered AC
> (inverter) to the GMC. The complicated 110 VAC switching and wiring
> are probably not worth the effort.
> I suggest that it would be better to buy several low power inverters
> that have their own power switches, AC connectors, and place them at the
> point of need. I buy these 300 watt simulated sinewave- inverters for
> $20 from Frys' electronics in CA.
> Buy one simulated sinewave inverter of the 1000 watt size, for the heavy
> loads.
> If needed, buy a low power pure-sinewave inverter for the noise
> sensitive stereo.
> Laptop (LT) computers charge an internal battery and do not require a
> clean power. I have used my Desk top (DT) computer on a simulated
> sinewave inverter with no problems. However if you are concerned about
> the power to your computer it is a relatively small load that could run
> on your stereo inverter. .
> SIM SINE
> Blender 300 X
> Can opener 100 X
> Coffee Maker 1000 X
> Drill 3/8" 500 X
> Frying Pan 1000 X
> Food mixer 300 X
> Hair dryer 1000 X
> Iron 1000 X
> Microwave 1000 X
> Reading lamp 100 X
> Television 700 X
> Toaster 1500 X
> Toaster over 1500 X
> Vacuum cleaner 1000 X
> VCR 50 X
> Stereo 500 X
> Computer (LT) 100 X
> Computer (DT) 300 X
> Soldering Iron 1000 X
> Impact wrench 1000 X
> >From this list you can see you do not need to buy a $1500 sinewave
> inverter to run your $100 microwave. Most of the AC loads in the Motor
> Home do not require pure sinewave power. The simulated sinewave
> inverters are more than adequate for most of the loads and if they
> create RFI (radio frequency interference) noise turn the invertors off
> when not in use. The 1000 watt inverters are typically on sale for $300
> to $500.
> Gene
> Gene 76Palm Beach /Or/CA
> GMC Technical Information
> http://www.california.com/~eagle/
Which inverter do you buy from Fry's? I'll there tomorrow and would like to look at it.
Henry
Soquel, Ca 95073 / IP reviews
fax: (408) 462-5198
http://www.henry-davis.com
> SIM SINE
> Blender 300 X
> Can opener 100 X
> Coffee Maker 1000 X
> Drill 3/8" 500 X
> Frying Pan 1000 X
> Food mixer 300 X
> Hair dryer 1000 X
> Iron 1000 X
> Microwave 1000 X
> Reading lamp 100 X
> Television 700 X
> Toaster 1500 X
> Toaster over 1500 X
> VCR 50 X
> Stereo 500 X
> Computer (LT) 100 X
> Computer (DT) 300 X
> Gene
Gene, Isn't your statement about the microwave in direct conflict with
your list? Looks to me like you have the sinewave as a requirement for the
microwave? Also, what happens if you run a color TV on a simulated sine
wave type? Is there allot of picture interference or??
Phil Swanson
Gene, Does Fry's carry an inverter any higher that 300 watts? Can
inverters be somehow wired in parellel to provide more capacity at one point
instead of having boxes all over your GMC?
Phil Swanson
Phil Swanson
There is a good article in the Motorhome 1999 guide "Dingy towing Special'
about the stat power 40+ and they speak glowingly of it. I am in the
process of looking for one this morning. The article convinced me.
>Phil
>Take a look at http://www.statpower.com/ t=_self]Statpower Index Page[/url]
>Take Care
>Arch
>point
>> Phil Swanson
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
> Phil
> Take Care
> Arch
> point
> > Phil Swanson
Gene,
I do nont see anything about index or page a??? I have looked at this
websight before. What am I supposed to see?
Phil
