Internal A/C system (New thread)
thom hole
212
I am looking for an A/C unit that I could use INSIDE my
Transmode-to-Motorhome project Coach. I have been thinking about a small
home unit where the Evaporator is next to the furnace and uses the same
duct work. The condenser and compressor would be outside in, say, a front
wheel well. I had picked up a lead that Sanyo made such a unit, but can't
find any reference.
Any suggestions?? I am attempting to keep the exterior of my coach a
clean and devoid of things like pods, rooftop A/C, 'mushroom' vents,
stairs, etc. I want it to just slip through the air like our LSR (Land
Speed Record) idea from a few months ago.
Thom;
Sanyo, Fredrick and a number of others make what is called a split system for
commercial residential use. Cost was over $1,200 for a rather modest unit. I
looked at these and the units I found all ran on 220 volts. The other
alternative is to look at a basement model from one of the larger coaches. You
could probably pick one up used from AZ RV surplus. Let me know what you find
out in your search, as I would like to do the same, but it is not a priority
at this time.
You may want to do a net search on Air Conditioning, Split system or basement
model RV.
Marcus
> find any reference.
>small
>same
>front
>can't
>find any reference.
>a
>(Land
Try Paul Loeffler who is not only a GMC owner (one of the first stretched
coaches) but an air con expert as well. He helped to develop the improved
engine air distribution system many owners have on their pre 1977
coaches.
You can reach him at pmloeffler and ask him about his home type
aircon system. Tell him I gave you his name.
David Lee Greenberg
Boston Homes, Inc
1220 US Highway 1, Suite B
North Palm Beach, FL 33408
www.bostonhomes.net
Thom,
Almost a month ago you asked where you might find an A/C unit you could
use inside your coach. I knew I had seen a picture of one, but just
could not remember which one of the many books and catalogs offered this
type of unit.
Yesterday I found the ad. Camping World catalog - Holiday edition -
page 45.
Duo-Therm 12,000 BTU heat pump that fits under seats or counters,
thermostatically controlled, blower operates manually or automatically,
weighs 70 lbs and measures 14 1/2"H x 21 1/2"D x 22"W. Part number
16082D, was on Red Tag special at $799 or $719 if you belong to
Presidents Club.
Hope you find this info helpful and if you buy this unit let me know how
you like it because I want to do the same thing.
terry
75 Avion
Baton Rouge
- --WebTV-Mail-1637758-1807
Content-Disposition: Inline
Content-Type: Message/RFC822
Content-Transfer-Encoding: 7Bit
Received: from mailsorter-102.bryant.webtv.net (209.240.198.92) by
postoffice-122.bryant.webtv.net; Fri, 26 Feb 1999 06:28:54 -0800 (PST)
Return-Path:
Received: from slowboat.mailinglists.org (slowboat.mailinglists.org
[12.4.96.5]) by mailsorter-102.bryant.webtv.net (8.8.8/ms.graham.14Aug97)
with SMTP id GAA19240; Fri, 26 Feb 1999 06:27:26 -0800 (PST)
Received: (qmail 12762 invoked by uid 108); 26 Feb 1999 09:27:21 -0500
Delivered-To: gmcmotorhome
Received: (qmail 12752 invoked from network); 26 Feb 1999 09:27:20 -0500
Received: from dogwood-fe0.cisco.com (171.68.122.251) by
slowboat.mailinglists.org with SMTP; 26 Feb 1999 09:27:20 -0500
Received: from thhole-pc.cisco.com (rtp-la2rear-dhcp-168.cisco.com
[161.44.26.168]) by dogwood-fe0.cisco.com (8.8.6 (PHNE_14041)/CISCO.SERVER.1.2)
with SMTP id JAA18891 for ; Fri, 26
Feb 1999 09:26:49 -0500 (EST)
Message-Id:
X-Sender: thhole
X-Mailer: QUALCOMM Windows Eudora Pro Version 4.0.2
Date: Fri, 26 Feb 1999 09:18:00 -0500
To: gmcmotorhome
Subject: GMC: Internal A/C system (New thread)
Mime-Version: 1.0
Content-Type: text/plain; charset="us-ascii"
Sender: owner-gmcmotorhome
Precedence: bulk
Reply-To: gmcmotorhome
find any reference.
- --WebTV-Mail-1637758-1807--
> Thom,
could
this
> type of unit.
> page 45.
automatically,
> Presidents Club.
how
> terry
> 75 Avion
> Baton Rouge
> ATTACHMENT part 2 message/rfc822
small
same
front
can't
> find any reference.
coach a
(Land
DO YOU YAHOO!?
Advanced RV products has same unit for $695
Will 1200btu be enough for the 26' GMC and how would we duct the
condensor air to the outside? Maybe thru the floor?
Herm
> Thom,
could
this
> type of unit.
> page 45.
automatically,
> Presidents Club.
how
> terry
> 75 Avion
> Baton Rouge
small
same
front
can't
> find any reference.
coach a
(Land
DO YOU YAHOO!?
Floor venting would be my first choice, which my orientation to keeping my
lady as smooth as possible. But there is seems to be these bothersome
thing caled gastanks in the way. I was originally thinking of a split unit
(like home units) that would put the compreesor any condcensor in a front
wheel well. This would get the sound and vibration away from the inside of
the coach.
And, yes, the question as to size is still unresolved. Maybe someone here
on the WEB has the experiance needed to calculate the correct amount of
cooling needed for a 26' by 8' by 6.5' tall space. I am unfamiliar with the
ratings on the standard roof mounted units. Eperiance with the cooling
capabilities for those units would be appreciated. Thx....th
My wife and I look forward to bring our lady (we NEVER use the 'beast') and
meeting Ya'all in Myrtle Beach.
>Herm
>> Thom,
>could
>this
>> type of unit.
>> page 45.
>automatically,
>> Presidents Club.
>how
>> terry
>> 75 Avion
>> Baton Rouge
>small
>same
>front
>can't
>> find any reference.
>coach a
>(Land
>DO YOU YAHOO!?
16082D, was on Red Tag special at $799 or $719 if you belong to snip...
Anyone have an opinion as to whether this unit could replace the gas
furnace in terms of space and would 12k btu provide enough heat for
lowest SE Florida temps of say 45F? Also could the existing furnace vents
to the side of the coach be utilized for this installation?
In my 1977 GM finished coach, the furnace is under the kitchen sink.
David Lee Greenberg F22009
GMC Motorhome Registry
200 MacFarlane Drive PH4
Delray Beach, FL 33483-6829
David I think the important question is can it heat the coach for a period
of time without the generator, ie; all night?
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Herm,
Don't know much about the unit, but venting it through the floor sounds
better than chopping another hole in the side of the coach.
Most of the new roof air systems seem to run between 7,000 and 13,000
BTU. Haven't had a chance to get the specs on the OEM unit in the GMC
(my books are locked up in storage with the coach).
Just thought I might offer the info on the unit as an option to roof
A/C. Hoping somebody would try it and let me know if it works and I
wouldn't have to be the pioneer of onboard A/C in the GMC.
So how do I get hold of Advanced RV?
Price is sounding better....would someone hand me that wrench?
terry
75 Avion
Baton Rouge
- --WebTV-Mail-1514854758-2477
Received: from mailsorter-101.iap.bryant.webtv.net (209.240.198.91) by
postoffice-122.bryant.webtv.net; Thu, 18 Mar 1999 10:19:23 -0800 (PST)
Return-Path:
[12.4.96.5]) by mailsorter-101.iap.bryant.webtv.net (8.8.8/ms.graham.14Aug97)
with SMTP id KAA22081; Thu, 18 Mar 1999 10:19:18 -0800 (PST)
Received: (qmail 2070 invoked by uid 108); 18 Mar 1999 13:18:30 -0500
Received: (qmail 2046 invoked from network); 18 Mar 1999 13:18:28 -0500
Received: from send1e.yahoomail.com (205.180.60.64) by
slowboat.mailinglists.org with SMTP; 18 Mar 1999 13:18:28 -0500
Message-ID:
Received: from [208.129.254.17] by send1e; Thu, 18 Mar 1999 10:16:59 PST
Date: Thu, 18 Mar 1999 10:16:59 -0800 (PST)
Subject: Re: GMC: Internal A/C system (New thread)
To: gmcmotorhome
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Precedence: bulk
Herm
> Thom,
could
this
> type of unit.
> page 45.
automatically,
> Presidents Club.
how
> terry
> 75 Avion
> Baton Rouge
small
same
front
can't
> find any reference.
coach a
(Land
DO YOU YAHOO!?
- --WebTV-Mail-1514854758-2477--
I have the OEM Duo-Therm roof mount A/C and Installation & Operating
Instructions manual. All models listed in the manual are rated at 13,500
BTU's. Other stats:
Volts - 115
Kilowatts - 1.8
Run Amps - 15.0
Total locked rotor amps - 78.0
Wire size - Up to 24' No. 12 AWG
Min. Generator - 3,500 Watt
Fuse size - 20 Amp Max.
Refrigerant Charge (R22) - 17 or 26 oz. (depends on model)
Models were 54615-035, 54615-036, (17 oz.) and 54615-045, 54615-046 (26 oz.)
If anyone needs additional info., feel free to contact me privately.
Chuck
North Idaho
Herm,
terry
75 Avion
Baton Rouge
Heat pumps have one thing in common. They don't work under 40 degrees. The
15K unit I have on the roof will heat 15K cooling and 12K heating. However,
if the outside temp is less than 40 it doesn't work at all. That is because
the unit will not transfer heat below that temp, and it will ruin the unit.
So if you are planning for a replacement for your heater, remember that the
unit won't really work when it is real cold.
Al Chernoff
advanced RV products:
http://www.advrv.com/index.htm
13,500
> BTU's. Other stats:
> Volts - 115
> Kilowatts - 1.8
> Run Amps - 15.0
(26 oz.)
> Chuck
> 77 Kingsley
> North Idaho
> Herm,
sounds
> terry
> 75 Avion
> Baton Rouge
DO YOU YAHOO!?
Tom, If I still lived in upstate NY that would be the important question
but these days I seldom travel in places that get really cold.
In fact, I don't use my gas furnace anymore. I use a 5,000btu cube heater
which satisfies our needs. Also little or no dry camping anymore. So,
back to the question of will the space accommodate one of these heat
pumps.
Dave G.
On Thu, 18 Mar 1999 17:41:17 -0500 (EST) "Thomas G. Warner"
>period
>vents
>Tom & Marg Warner
>Vernon Center NY
>1976 palmbeach
