Hello All, greetings from Ontario, Canada. Hope you are enjoying your weekend.
Well I finally got my, new-to-me, 1975 GMC Royale home.
After a long search I narrowed it down and with a PPI from one of the best shops in Ontario, Frank Borrmann of Borrmann's Garage I was able to secure
my first GMC Motorhome. The 2.5 hour drive back home was without issues and the clouds and rain didn't diminish my excitement, what a COOL ride.
I'm not that mechanically inclined and have very little experience with plumbing and zero experience with electricity. There you have it, but I have a
desire to learn and be very hands-on with my planned interior update. The coach has had many mechanical updates so my winter project will be limited
to the interior... for now. My shop where I will be working is heated with plenty of space, most tools, air compressor and welder.
I have many questions, I thought the months of research prior to purchase would have prepared me, however, my theoretical knowledge hasn't caught-up
to my plans for this project, yet.
I have participated on the forum in a limited capacity asking for some help and have been impressed with the level of assistance and willingness from
forum members to provide help. My plan is to join the Heritage Cruisers club and look forward to a rally or two.
Please feel free to provide answers or direction to links where I may find the solution I'm looking for... photos also work best for me.
1) I have removed the rear overheads although I don't plan on removing the fronts, are there any concerns I should be aware of or tips to utilise if I
install a new headliner around the various areas such as front overhead as well as the bathroom and closet areas?
2) After pulling down the material the sub-surface appears to be in good shape except for the glue. Would you recommend I remove this surface by
cutting around the front overheads etc or leave it in place and install the new headliner (not yet decided on but I like the FRP idea) over top of
it?
3) Are there line drawings available or similar which shows the locations with dimensions of the aluminum interior structure? I have searched a found
some good information but was hoping for something more specific if it exists?
4) I will be using power from my shop and will not require use of the batteries, does disconnecting the chassis and house batteries allow for
electrical boxes, outlets or connections etc to be accessed without fear of causing damage or shock?
5) Should I disconnect the generator battery as well, anything else to know if not using the generator until spring?
6) Would you recommend raising the coach off the ground, on stands / blocks to alleviate stress on the air-bag system etc? As I mentioned I probably
will not need to get under the coach for work but you never know?
7) What is your opinion on the Hepvo sanitary waste valve, I plan to replace the sinks in both the kitchen and bathroom?
I'm certain I will be adding questions to this list as I progress with this project, any guidance or suggestions beyond my questions will be greatly
appreciated.
Thank-you for your help,
Stay Well,
Mike
it?
appreciated.
Stay Well,
Mike
