Interior Doors
phil swanson
660
I was wondering if anyone had a problem with the bathroom door flying
open while underway. The original latch is very small and doesn't seem
to have much to hold on to when the door is closed. I hate to add one of
those tacky latches where you slide a pin over and down but I may have
to. Has anyone replaced the stock latch with an improved version that
doesn't look like an add on?
By the way I have a 73 Canyon Lands 23 footer.
Thanks, Phil
Swanson
Had trouble with mine and fixed it. There is a small ballbearing inside the
slide that gets stuck. Take the latch apart and clean it, lightly oil and
mine works perfectly again.
> Thanks, Phil
>Swanson
Phil,
New origional style latch assemblies are available, give me a call if
you need one. 1-877-275-4462
Jim Bounds www.gmccoop.com
> > Thanks, Phil
> >Swanson
One thing I forgot. check around your bath module and see if the floor is
rotting underneath and around the module causing the whole module to rack
and move.
>Phil, my latches (bath & Closet) work just fine. Occasionally you have to
>tighten the knob but your door may be leaving a wider gap and the latch
>seems too short to hold. Or if the door is flexing while under way that
>may cause the latch to not hold.
>One suggestion, for waht it's worth would be to disassemble the latch and
>see if a longer tongue would do the trick.
> Dave Greenberg
>GMC Motorhome Registry
> 200 MacFarlane Dr
>Delray Beach, FL 33483-6829
> 1977 Eleganza II
