Interesting Crankshaft/Torque Converter Notes
patrick flowers
1,460
I received the following today off-net. I've sanitized it slightly to
protect the guilty. I hope the author will forgive me, but it's just
too good to keep under my hat. This old dragon has been flushed into
the open - it's time to spear it one last time.
Patrick
> Now this is interesting so I thought I'd pass it on.
> I just finished talking with the Owner of the largest crankshaft
> remanufacturing company in XXXXXXXXX. The owner has worked his way to
> ownership the hard way. His whole life has been crankshafts and he is
> indeed one of the best IMO. Having given him an intro, I'll move on.
> I asked him about thrust problems on 455 Olds engines. He said that he
> doesn't see that often enough to consider it a problem. The few that he
> has seen that he thinks are torque converter related he feels are in
> situations where the owners are winding motors too high. Not our
> situation. The single biggest problem is the one we all agree on and
> that is spinning the #1 or 7 rod bearings. He attributes this to the
> poor design of the big Olds oiling system. No surprise to any of us I'm
> sure.
> The surprise though is in the fact that he states that 1 out of every
> 10 big Olds crankshafts he does see has NO filet radiuses from the
> factory and it's too costly to make/restore them. I realize that this
> does absolutely nothing to help clear up our mini-controversy but I
> thought I'd pass it along.
> Later....
> I just finished a long talk with a transmission builder who's been in
> business at the same location for 27 years. He started out working for
> his father, now he's owner and his son's getting ready to come and work
> for him. When I was in the engine building business he did over 78
> transmissions for me and my customers and I had a single failure. (The
> transmission was in a car used mostly for drag racing.)
> He pretty much confirms that t-400's are harder on crankshafts than any
> other transmission. They do have a pressure regulator but it doesn't cut
> in at anywhere near what others do. This is part of the key to the
> durability of the T400, as well as being responsible for some of the
> problems they cause on any crank other than one that is exactly at spec.
> I asked him about downshifting using a kickdown switch vice using the
> shift lever. He says that manually selecting a lower gear does indeed
> engage an extra compression band and does put more stress on parts. It
> is there for "deceleration" purposes. Use the kickdown switch for
> acceleration and your transmission will be happier.
> I asked him about thrust. Like most of our transmission builders out
> there he says it's usually the fault of the crankshaft regrinder/engine
> rebuilder. He feels strongly that you will never experience a crankshaft
> failure (other than old age) by putting a rebuilt trans/converter behind
> an original, good running engine. But put a freshly rebuilt engine in
> front of an original converter/transmission combination and you will have
> a situation where most of the engine failures occur. The crankshaft
> preparation is the real key here.
> As I have said before....the highest price I've ever paid for a
> crankshaft regrind is $45-$50 plus bearings and plus the cost of the wet
> magnafluxing, usually an additional $15 for the latter. These are jobber
> prices. A Mondello prepped crank is $750. Bob Lamey pays $450 for his
> favorite shop to prep his crankshafts. These are not jobber regrinds.
> You get what you pay for really applies here.
Patrick Flowers
Mailto:patrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
Before we go spend some more money, I'd like to hear any logical desenting
views to what Patrick quoted;
Since we do all our downshifting with the lever (bad solenoid), I'm worried
about adding stress to our old oem tranny. Besides the money, is there some
reason we should not fix the downshift function.
And then a second question; if we're going in to replace the solenoid,
would this be the right time to also put in the shift kit?
Dave (advisor/navigator) & Dege (ALL else), '76 Royale, Santa Barbara, CA
