Some progressive and others offer a Agreed Value on the coaches.
With out that, they will say it is worth 5K and should you get into an
accident the repair will be high enough and they will Salvage the coach.
We do an Independent Appraisal which you can use to get the agreed value
which indicates a true value and your protected.
Not every agent is allowed to do as some are questionable people and they
are not allowed to do Agreed Value at all.
The key word is AGREED Value.
I can help you with that .
> Depends on what state the coach will be principally garaged.
> Progressive writes a lot of RVs, but Im not sure they write them in all
> states.
> It also depends somewhat on the overall condition of the coach. If its a
> normal nothing special roadworthy coach that may open up some more
> carriers.
> If its a 200K spent full restoration there will be less carriers willing
> to write the risk if the buyer wants an agreed value type of policy.
> Easiest thing would be to have the buyer contact his/her current agent and
> see what carriers have an appetite.
> 77 Royale, Rear Dry Bath. 403, 3.55 Final Drive, Lenzi goodies, Patterson
> carb and dizzy.
> Mid Michigan
http://www.appliedgmc.com
