This is on the GM TBI ECM '747
The wires in the factory harness to Injectors 1 and 2 are twisted into pairs with 2 12V supply wires.
I assume this is to prevent the signal from creating noise in the surrounding sensor circuits as the injectors 'fire'.
Is the twisting required ? I haven't seen this mentioned in any of the supporting documents I've reviewed including schematics from GM.
Did you do this, or see it in your harness? Or were the wires run straight?
Thanks for any insight.
Todd
Todd
