Well, I guess I've had my head screwed on backward for quite some time:
I've been thinking, and discussing, the use of offset bushings in the UPPER
REAR of the upper A-arm. Tonight, I've been researching offset bushing
part numbers. LO and BEHOLD: Moog (and everyone else) ONLY mentions
eccentric (offset) bushings for the upper FRONT! NOT the rear! Holy Moly,
why hasn't someone called me on that? Or have we GMCers been "doing our
own thing"?
Here are the ONLY Moog part numbers I've found for '76 Toronado (and by
extension GMCMH):
Standard Offset(Eccentric)
Upper Front K7006 K7104
Upper Rear K6111
Lower Front K5222
Lower Rear K6116
Does this mean that the K7104 will ONLY fit the Upper Front, or merely that
that's where they're recommended (but CAN fit the rear?).
Come on, somebody straighten this mess out.
On Wed, Jan 20, 2021 at 9:01 PM Ken Henderson
wrote:
> I've got another question (or more) for this survey:
> 1. Is it feasible to use offset bushings in both the rear AND front of
> the upper A-arms? Seems to me it should be perfectly OK and potentially
> give about twice as much caster increase as using them only in the rear.
> 2. Seems to me installing the offset bushing in the rear, to increase
> caster, would inevitably tend to move camber toward negative. By the same
> rationale, using offset bushings front and rear would have less effect on
> camber because the front would tend toward positive camber about equal to
> the rear's negative effect.
> 3. Has anyone considered or tried the offset upper A-arm shafts? Like
> this:
bit.ly/3obunmp
> or
https://www.globalwest.net/billet-steel-stock-upper-control-arm-offset-cross-shaft-camaro-67-68-69-global-west.html
> I have no idea whether those are available to fit the GMC, but we've got
> plenty of folks capable of designing and building them. It might be easier
> than modifying A-arms, as Lenzi does. What are the pros & cons?
> 4. Other options?
> Rest assured, I'm just trying to learn something here -- I'm happy with my
> 1-ton front end -- and it was installed before Manny decided to increase
> the caster. (I THINK I did use offset bushings in the rear though -- tooo
> long ago for my old memory to be sure.)
> Thanks for all your inputs/ideas.
> Ken H.
> On Thu, Jan 14, 2021 at 11:42 AM Ken Henderson
>> Time for a survey of those using Dave Lenzi's upper A-arms modified for
>> increased caster:
>> What's your opinion after using them for a while? Do they significantly
>> increase the steering stability? Did you try the offset bushings before
>> going to modified A-arms? How do they compare? Did either affect the
>> steering effort significantly? Which is the "better buy" -- or is either
>> worth the trouble/cost?
>> Thanks for your opinions.
>> Ken H.
