I agree with all that Ken H has stated. However when you run your test using the auxiliary 5 gallon tank I would also remove the filter going into the carburetor.
Sent from my iPad
> slc,
> You've gotten LOTS of advice, most of it good, some excellent. I'm goint
> to tell you what I'd do:
> First I'd be sure the electric fuel pump is OFF. Then I'd disconnect and
> plug the short rubber coupling between the fuel tank supply line and that
> leading to the mechanical fuel pump, thereby disabling all of the GMC's
> fuel system. That coupling's at the right front side of the 2nd (main)
> chassis crossmember.
> Since I have a 5 gallon "jerry can" with an attached electric fuel pump,
> I'd set that on the front bumper, and connect it with rubber tubing to the
> carburetor with a short metal adapter. However, you said you've used a
> gravity fed system in the past -- do it again, 'though I'm surprised you
> get enough fuel pressure & volume to support much engine load.
> Drive enough with that replacement fuel system to convince yourself that
> you've eliminated the problem; I'm confident that will prove true.
> If it IS a fuel problem, get those tanks down again if possible to be sure
> all the lines are properly attached, routed, and undamaged. REMOVE the
> "socks" from the fuel pickup tubes. I'd suggest replacing all the rubber
> lines with 3/8" steel while the tanks are down, but it's not mandatory. DO
> check whatever tubes you install for clear flow.
> With the tanks back in place, remove and sell to some other sucker that
> fuel selector valve -- it's nothing but a problem waiting to happen, IMHO.
> You haven't said what kind of electric fuel pump you're using, but it's
> apparently OK. I personally use nothing but Carter 4070's for low
> pressure. With large, easily accessible inline fuel filters BEFORE the two
> fuel pumps, combine their outputs with a tee into the hard line leading
> forward. While the 4070 does not require them, I install check valves at
> the inputs the tee just in case I have an emergency need to install a pump
> which requires them.
> With a 12VDC SPDT relay controlled by the wire originally serving the
> selector valve, supply the two electric pumps with independent 12VDC power
> through a circuit breaker and a low oil pressure switch (or other safety
> shutoff), using at least 16 gauge wire.
> With that fuel system, there's hardly any chance of your experiencing fuel
> starvation. And if you do, by simply switching the Tank Selector switch to
> the other tank, you'll transfer about 95% of the fuel supply system to
> different components. You'll probably never experience fuel starvation
> again, even from vapor lock.
> The redundancy is more than worth the slight additional cost of the 2nd
> pump vs that of the selector valve.
> JMHO & JWID (Just What I've Done),
> Ken H.
>> On Mon, Jul 27, 2020 at 8:10 PM slc via Gmclist
>>> If it really is 133 K miles could this be a case of the timing chain
>> finally skipping at least 1 tooth ? There have
>>> been a few methods posted a checking timing chain slack/tension without
>> serious taking apart. Might a reasonable place to start
>>> be, is the rotor in the distributor in the right place when cylinder #1
>> is at TDC on the firing stock? Step 2, if step 1
>>> is OK, we need someone to post the easiest way to check timing chain
>> slack without serious dissasembly Ken B or Matt C, any ideas
>>> here? Everyone feel free to chime in.
>> ok QUESTION
>> If the timing chain had skipped a tooth, wouldn't the engine run
>> terribly all the time, miss, etc?????????
>> I ask this because until the power loss happens, 27 to 32 mph, the
>> engine fires up and RPMs climb just like normal, strong, smooth.
>> I am thinking if the timing is messed up, it would not have that smooth
>> strong power build up, RPM climb in the beginning from low RPM up.
>> OK so at a full stop, engine running, brakes on. the engine runs at good
>> idle, strong, no missing. Press the accellerator down, the engine will
>> raise the RPM normally, no missing, strong climb until it reaches that 20-
>> +, when it get to that point, the power loss happens. But if the RPMS
>> go down, the engine smooths out and I press the pedal, the engine reves up
>> to the point where the power loss occurs. then repeat the above again.
>> This is more or less exactly what I experienced, more or less, after I
>> left that shop when the Tanks and hoses were changed all those years back.
>> I
>> have had her running at 75 mph since until this happened again.
>> I do not believe the chain would slip BACK into normal position on the
>> gear.
>> But I will try a couple things and if it gets more rediculous, will try to
>> check the timing chain too.
>> thanks you all.
>> GatsbysCruise. \
>> 74GMC260 Former Glacier Model style. \
>> Waukegan, Illinois \ Keep those MiniDiscs Spinning \ MY GREYHOUND IS
>> FASTER THAN YOUR HONOR ROLL STUDENT \
WindowsXP-Win7-Win8.1-UBUNTU STUDIO -
>> UBUNTU VOYAGER - Berzin Auto Center
