I have a quiet fan that runs when needed.
Seems like it needs to be engaged when AC is on and speeds below 45 MPH to keep the high side from kissinng the 300 PSI mark. Now we are getting into
modern ecm territory with VSS and such. Having the AC dash switch simply latch the fan relay woukd work but then it would be on all summer. But if
the new blade is less parasitic it might be ok
Matt, I know that changing a bunch of stuff at once is a recipe for
disaster. In this instance, the owner wanted everything NEW AND TROUBLE
FREE. HIS DECISION TO DO THAT. IT was not just changing but the combination
of the changes that bit me. I know better.
On Jun 26, 2017 10:06 AM, "John R. Lebetski"
Jim, I'm not sure I get what the problem was. By "stabilize," I am reading
"stay within the acceptable range" and not "stay at a single temperature no
matter what happens." The thermostat on the fan clutch is mechanical--it
uses a bimetallic strip to engage and disengage the fluid-damped clutch.
That thermostat is controlled by the air temperature in front of the
thermostat. The thermostat on the engine is controlled by the coolant being
pushed into the engine by the water pump.
My severe-duty clutch is supposed to "come on" when the air temperature is
around 210 degrees. As you point, that varies a lot from one clutch to the
next. But, for me, the fan may come on over a range of engine coolant
temps. The engine thermostat opens when the water temperature exceeds 195
degrees (when using the stock 'stat) or 180 degrees, using the 'stat many
of us use (including me). And, of course, neither thermostat is a
switch--it starts to ease open a some temperature, and becomes fully open
at a different temperature. The second temperature in the open or close
action may vary based on the relationship between the conditions causing
the temperature change (such as the steepness of the climb) and the damping
within the thermostat.
It is quite likely that these will chase each other to some extent. The air
temperature in front of the clutch is subject to a variety of influences,
but when traveling at speed, we would think it would be lower than the
radiator temperature (which should be close to the coolant temperature).
That's only true if the engine compartment scavenges air out of the shroud
area effectively, which it doesn't when the fan is freewheeling. The heat
bubble from the engine may extend into that zone. When it does, the fan
clutch will engage more readily. I know this happens, because my clutch
engages from time to time even when the coolant temperature is steady below
190 degrees. Something is pushing that clutch thermostat up enough to get
it to engage from time to time. It's not my air conditioner, which right
now is not capable of moving heat anywhere. It happens more in traffic. Of
course, the transmission and engine oil also heat the radiator, but the
temperature gauge is measuring the cumulative effect of that addition, plus
the cooling effect of the radiator. (My gauge is a mechanical Autometer
gauge, so I don't depend on an electronic sensor).
When the clutch engages, the coolant temperature drops like a stone, from
195-200 down to 178 or 180--by "like I stone", I mean within 15-30 seconds.
That's with a factory fan and severe-duty clutch. I conclude that when
driven, the factory fan is exceptionally effective.
So, the result is an oscillation between the lower control, which is the
engine thermostat, and the upper control, which is the fan clutch
thermostat. I expect there are times when they are reversed, and the
natural damping of the thermostats allows that to resolve itself. Some may
interpret that as "unstable".
The one element in what you did to Jerry's coach that I have no experience
with is the water pump. But the aluminum radiator is bigger and more
efficient, which means it will dump hot air on that fan clutch thermostat
more quickly than the stock radiator. That might make the oscillation
worse, so that the fan comes on more readily, but turns off more readily,
too, with less damping just from the time it takes to change the
temperature of the coolant..
A fan clutch switched on the basis of engine coolant temperature should
reduce that oscillation, simply because the fan will now be reacting to the
same thing the engine thermostat is: The coolant temperature.
The oscillation used to bother me, because it would often happen at speed.
I would have thought ram air would be enough to cool the radiator. But
no...even at 60 mph cresting a long hill, the fan will come on and the
coolant temperature will drop like a stone from 195-200 down to the 180
setting of the engine thermostat. The fan is therefore MUCH more effective
than ram air. But then I decided the system was working.
The stamped metal fan is effective but it is not efficient--it moves a lot
of air, but at the expensive of a lot of wasted energy--wasted on robbed
horsepower and on noise. That's where an engineered plastic fan should be
able to do better.
Rick "thinking fan clutches have caused about as much discussion on GMCnet
as tires and combiners" Denney
> I guess I am feeling a bit "snake bit" when it comes to new innovations in
> fan and "high flow?" Aluminum water pumps. When I replaced the engine in
> Jerry Work's Clasco coach, we put in a new aluminum radiator, new 10 blade
> plastic fan and clutch, 2 piece shroud, aluminum water pump, the whole
> enchilada. It would not stabilize coolant temps. I finally wound up doing
> a 100 mile service call to re-install the original style water pump and
> steel stock fan, along with a new thermostat. That fixed the temp cycling
> problem. I am a bit leary of going through those motions again with "new
> and improved parts". But, that does not mean that the cooling system does
> not need improvement, it does.
> On Jun 26, 2017 8:21 AM, "Johnny Bridges via Gmclist" <
> > Relative to Hupy's comments, the new setup uses coolant temperature to
> > turn the clutch on or off. The temp sensor is a lot more accurate than
> the
> > temperature of the air going across the clutch. The fluid sees only one
> > seal instead of two, and the design and materials of that seal are 40
> years
> > newer than the original. Consequently we feel it will work better and
> > last longer.
> > --johnny
> > 76 26' Eleganza(?) with beaucoup mods and add - ons.
> > Braselton, Ga.
> > "I forgive them all, save those who hurt the dogs. They must answer to
> me
> > in hell" - ol Andy, paraphrased
'73 X-Glacier 230 "Jaws"
Northern Virginia
> into modern ecm territory with VSS and such. Having the AC dash switch simply latch the fan relay woukd work but then it would be on all summer.
> But if the new blade is less parasitic it might be ok
John,
That would be a simple thing to add to this system. A surface temperature switch on the discharge line set to about 160°F. When that happens, the
fan runs.
So, all the guys have to come up with is a FCU (Fan Control Unit).
Want it to come on continuously under 45MPH? Simple. Press the MANUAL switch. Ensure that the FAN ACTIVATED light illuminates. Do so passing down
through 45mph.
Want it to come on when the A/C is on? simple. Press the MANUAL switch. Ensure that the FAN ACTIVATED light is illuminated. Do so when you turn
the A/C on. Want it to come on when the A/C compressor clutch is activated? I'll be pleased to show you how, but you will be adding a potential
failure point. I'd suggest you simply turn it on manually if you think things might get hot. If you don't, the coolant temp sensor will do it for
you. You can label the switch and light any way you please.
We consider and quickly rejected a manual engagement in favor of the viscous clutch. The water pump bearings aren't designed for shock loading, and
would probably die fairly rapidly, even with the supplied light weight plastic fan. Actually, it looks like nylon, I've no idea what it's made of.
This fan clutch is the one that the Mercedes use on there 1ton vans.
It is signaled from the box that was designed by Johnny Bridges to operate
from the temp switch as well as a manual switch.
So the fan clutch is rather simple as there is not heat strip or coil.
I have worked on several projects with Tom Prior and I hit him with hard
questions. I'm not committing to a product that does not work.
> able to do better.
> in
> blade
> doing
> > Jim Hupy
> > the
> one
> > years
> > > last longer.
> > > --johnny
> > > Braselton, Ga.
> > me
> > > GMCnet mailing list
> Northern Virginia
