Just a suggestion on use of the hydraulic jack. When putting in storage
keep the valve (or front) toward the top when you lay it down. Some time
ago when I went to use it, we discovered that some on the fluid had leaked
out over a period of time.
As a result, the jack would only raise the coach part way. Fortunately we
were not out in the boonies.
Checking the fluid, we then added what had drained out and jack worked just
fine. And you know the rest...since that time, we always check the jack in
storage to make certain it is face up both before, during and after a trip.
Glyn
76 Glenbrook
Glyn
76 Glenbrook
