If you buy the front bearing puller and OTC927 the insert that comes with
the puller will do exactly that.
>Scott,
>The GM service procedure requires using a slide hammer to pull the hub out
>of the knuckle. You can probably use a harmonic balancer puller to push it
>out like the Thoma tool if you make a push-plate to fit inside the knuckle.
>Patrick
>> Tom!
>> Thanks for the reply-- I still can't picture it--what website
>> is your puller
>> on? --I need to get a handle on what you are explaining.
>> Scott
>Scott,
>Patrick
>> Tom!
>> is your puller
>> Scott
