No zerks here. Not sure if the threads cut in the hub for the zerk fitting
would make it more likely to crack or not. I haven't heard any problems
though, so it must be ok. I have heard stories of people that have blown
out their seals using the zerk leading to loss of grease/failure though so
follow Heinz's warning to be gentle when putting in grease. It also
doesn't get any of the old grease/dirt out. Heinz's success indicates that
this might not be a problem either, so it sounds like a good way to go.
We do have a tool/method of greasing our bearings without removing them
from the hub. The hub assembly has to be removed from the GMC, but it does
allow the old grease/dirt to be removed. We even used it to pack a brand
new bearing as it did a much better job than our hand
packing. Unfortunately, it doesn't look like we will ever be able to
produce it. The racing and maintenance just take up all the free time. I
have taken the product stuff off of the web site for this reason.
Now would be a good time to mention that I am changing ISPs. My erols.com
email address will no longer be valid. The Seemann Motorsports web page
has been moved to http://smsgmc.virtualave.net . The frame off page is
still at http://smsgmc.webjump.com .
Zak
>-- [ From: Eugene Fisher * EMC.Ver #3.1a PRODIGY ] --
>Seems like we talked about this a year ago. I thought Zak had Zerks on
>his hubs also, and then there was a page where someone was going to sell
>just such a system. I not sure where all this is hidden, but I do
>remember it. (Not sure about Zak but he will let us know) You can
>clearly see the Zerk on the Wallace pictures.
>As Heinz is saying, the worry was blowing out the seal with too much
>pressure. And--- where does that pesky grease go any way, I like Heinz
>suggestion, just fills in the cracks.
>Sort of the way icecream does when you are too full to eat any more.
>gene
Zak
>gene
