Tom
When we get together at Darren's for a wheel bearing marathon we will take
as many pictures as we can, maybe even some movies. If you have anything
you think we should be sure to cover just let us know and we will attempt to
eliminate any confusion. If we do movies we could possible put them onto a
CD so anyone could play them on their computer.
Dave Mumert
dave
To:
Sent: Saturday, July 01, 2000 8:08 AM
Subject: Re: GMC: Hub Fit
> Tom
> I wonder if you yourself would write up an article on exactly the PROPER
way
> to use your PULLER as most of it has come as bits and pieces over time on
> the net. From what I have seen we may not have the expertice to do this
job
> unless we are able to observe it done, so in case we are somewhere that we
> have to have the bearings replaced we would like to be able to present the
> mechanic your puller along with the right instructions. Maybe you have
> allready done this?
> Marlene
> From: tom warner
> To:
> Sent: Saturday, July 01, 2000 6:00 AM
> > The outside dimension of the hub is not a minimum of 2.001" it is
2.0015".
> > I have no problem with anyones work and certainly not Ken Thoma's but
> quite
> > frankly in my opinion this idea of the hammering of the hub and knuckle
> > reducing either the hub or knuckle dimension is pure poppy cock. How
could
> > anyone ever come to that kind of conclusion? This story is in the same
> > leaugue as the horror stories about how weak the front wheel drive is in
> the
> > GMC motorhome in the first place, which led to the development of the
> > wallace bearing which in my opinion again is a total waste of money and
> not
> > as strong as the original.
> > I have seen many coaches that have been PROPERLY serviced at the
> prescribed
> > intervals and run over a 100,000 miles on the same bearings, hubs, and
> > knuckles with all of them still in perfect shape. How do these experts
> > account for these coaches?
> > The things that ruin the hubs and knuckles is in my opinion two things:
> > 1. NO service at all
> > 2. People servicing their bearings without the proper tools and
knowledge
> > I just got thru reading the info on this site,
> > http://www.california.com/~eagle/front.html, site on front
wheel
> > bearing service and again in my opinion it contains so many errors that
it
> > is really doing a disservice to all of you. I am not knocking the site
> since
> > I access it continually, its a fine site, but in the instance of the
> > evaluation of the pullers and methods it is very short sited.
> > Statements like this just make me livid as they once again start up the
> same
> > old myths that we have tried so hard to eradiacate.
> > "You'll need at least a 3' x 3' minimum HARD surface to hammer on the
> > removal construct once the OTC puller is attached. It ain't fun and you
> > have to use the OTC puller crossbar as a lever when you're hammering.
In
> my
> > case, it was 3 hammer blows for a 60 degree turn on the screw before
> > repositioning the wrench."
> > "Even if you succeed in removing the bearing set out in the boonies,
IMHO,
> > you'd be hard pressed to be able to install bearings in the field using
> the
> > (first 15) Warner puller without introducing contaminants on the new or
> > repacked bearings on install. The "pushing" pilot's collar should've
been
> > thicker and coarse knurled, for instance, enabling you to stop it from
> > turning with the screw with your Mobil One covered fingers rather than
> using
> > a tool. Hey I was a journeyman toolmaker in my previous life."
> > I am just preparing for a trip or would talk even more about this but I
> hope
> > everyone understands. There are no problems with either the tool or my
> > methods. There are only problems with people not understanding how to
use
> it
> > and follow directions.
> > tom
> > >In a message dated 6/30/00 10:01:23 AM US Eastern Standard Time,
> > > The way I understand it, both the hub and knuckle lose their
dimensions
> over
> > > time because of the force exerted on them(Ken Thoma referred to it as
> > > "hammering" in our conversation at Marion). The original machining
> marks
> > > may be there, but they may still be out of spec. The spec dimensions
> were
> > > in a Cinnabar newsletter and are probably posted on the net somewhere.
> > > IIRC, the hub minimum is 2.001 inches and is pretty easy to check - be
> sure
> > > to check in several places along the length of the hub surface. I
don't
> > > remember the knuckle maximum, but you need a good inside micrometer to
> check
> > > it. You can carry them to a good machine shop and they should check
> them
> > > for you for a modest fee(cheaper than a good inside mic).
> > > Patrick >>
> > >Oh H E double L
> > >I've got the whole thing back together. I can tell you this though. It
> took
> > >30 ftlbs of torque to drive on the bearing onto the hub. TOM, what is
the
> > >thread pitch on your puller, that will tell us what force it took to
> press
> > >mine on.
> > >As always
> > >Happy Camping:
> > >Mark A
Dave Mumert
dave
To:
> Tom
way
job
> allready done this?
> Marlene
> From: tom warner
> To:
2.0015".
> quite
could
> the
> not
> prescribed
knowledge
wheel
it
> since
> same
In
> my
IMHO,
> the
been
> using
> hope
use
> it
> > tom
dimensions
> over
> marks
> were
> sure
don't
> check
> them
> > > Patrick >>
> > >Oh H E double L
> took
the
> press
> > >mine on.
> > >As always
> > >Happy Camping:
> > >Mark A
