Hello all.
While on a trip we just found that one of the original tees behind the electrical cabinet has a pin leak and is cracked. I started to look at its
connections and having a hard time finding a tee that will directly replace it. The original gray tubing appears to be half inch, but has a flanged
end on it with the plastic nut. The plastic nut appears to be a half inch NPT thread, but I am not able to find a tee that has the correct flanged end
for the gray tubing to fit.
Does anybody know if these connectors are still available somewhere? The only other thing I could think of is to cut the flanged end off and see if a
tee with a pex or compression fitting will work. But, I don't want to cut off the end until known for sure.
Appreciate any help on the matter, should be a simple fix once I can find the correct parts.
Thanks!!!
Chris S. -
77 Kingsley, 3.70 FD, mostly OEM -
S.E. Michigan
Thanks!!!
Chris S. -
S.E. Michigan
