How important is it to unload the front and rear for greasing?
s-m-h
135
1
Continuing on with getting this ole girl happy again I am next going to get into greasing. In my research it seems as though some suggest unloading
both the front and rear. I am not really set up to have her elevated yet but would still like to get on with it. Is it crucial? I have shocks on order
so I will, at some point, have to get her up in the air. Should I just wait?
Thanks again for sharing your collective wisdom. It has been most helpful.
Cheers,
Shawn
Shawn Harris
1977 Palm Beach 403
Bone stock - gutted interior
North Vancouver,
Canada
Of your not going to drive it for a while I wouldn't sweat over it. I tend to do things in blocks together....ie: change + grease.
Unloading the components allows space usually to add the grease...so if it's called for you should do it that way.
Rich Mondor,
Brockville, ON
77 Hughes 2600
I feel that greasing the coach is very important.
It is ideal to relieve the pressure to lib properly, but when I see how the
Big Fleet people lib their units without relieving, I say it is more
important to lib it than to Waite for the proper set up.
On Wed, Sep 25, 2019 at 8:44 AM Shawn Harris via Gmclist <
> order
> wait?
> Cheers,
> Shawn
> Shawn Harris
> 1977 Palm Beach 403
> North Vancouver,
> Canada
I agree with Jim but my thinking is......as an example....we will not be driving our coach anymore this year as it is fall, so im not going to grease
it unless im doing some work BUT it will get greased in the spring before it gets put back on the road at which time i will grease as per the
recommended procedure.
Rich Mondor,
Brockville, ON
77 Hughes 2600
The only 2 things you CAN unload are the lower ball joints and the bogie bushings.
Occasionally I put the jack hook and bottle jack on a side in back and blow off all air on that side, then grease. In between (like at a rest stop
after 1000 miles or driving in rain or dirt) i grease the rear as it sits.
In front you'd have to put a jack under the lower cont arm to take load off lower joint, but then it's in the way AND I'm not getting under there
while on a floor jack, even though it could only re load on the tire. That front balljoint boot holds considerable grease And I only use the
Valvoline full synthetic.
Simply jacking the front til tires off ground will not unload as there is still lots of torsion bar windup.
I must say that I don't unload to grease. I figure that the first bump I
hit is going to move the grease from the previous void to the new, bump
created, void. If someone can show me evidence to the contrary, I may
reconsider.
On Wed, Sep 25, 2019 at 3:49 PM John R. Lebetski via Gmclist <
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
That makes no sense. The grease holes are in between the gap in each bushing set. Are your bushings so worn the pin is contacting the arm and pinching
off the flow? There is X amount of tolerance in the bushing to pin fit. Loaded all the slop would be at the top of pin. Relieved it may he more
evenly distributed.
There are no grease seals or dust shields on the bogie pins. They are
bolted rigidly to the bogie box. They do not move. The steel backed bronze
bushings are pressed into the arms, which move less than 1/3 of a turn.
Matters little whether you Jack up the coach or don't. Grease them until
you see old grease displaced by fresh grease, wipe off the excess, clean
your hands and forget about them until next service. JWID
On Thu, Sep 26, 2019, 9:29 AM John R. Lebetski via Gmclist <
> pinching
> evenly distributed.
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
There may not be seals any more, but they start with them. There is a
O-ring on the pin where it goes through the top-hat bushing, and “seals”
around the edge of the thrust washers that seal against the brim of the
top-hat on one side and the bogie arm on the other. When these seals are
fresh, added grease inflates them, so the seal is working. The original
seals have a square section, but pin kits often include o-rings instead.
JimK sent me the square-section seals when I rebuilt the new bogies I
installed this year.
Granted, the first time I added grease to my old bogies, I saw pieces of
those seals being pushed out, so I doubt very many of us still have them. I
ran it that way for 15 years, hoping my grease-adding was frequent enough
to push dirt out.
Rick “not adding more grease until the new seals wear in a bit” Denney
On Thu, Sep 26, 2019 at 1:12 PM James Hupy via Gmclist <
> Salem, Oregon
> > pinching
> > evenly distributed.
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
'73 X-Glacier 230 "Jaws"
Northern Virginia
On the rear: With bogie greasers on newer coaches that have the larger
pins, a squirt from a grease gun in each zerk every kilomile is enough.
With early coaches that feed grease to both bushings from a single hole in
the middle of the pin, the grease will all go to the looser bushing. That
design may benefit from being unloaded and manipulated when adding grease.
I did it that way once in a while but usually not. My bogies were as loose
as a wiggly shopping-cart caster, though, so maybe the damage was already
done. The new ones I just installed are the later type.
I never unloaded the front suspension when I hit all the zerks.
Rick “hard to go wrong with ball joints and tie-rod ends, except for
breaking off the zerk” Denney
On Wed, Sep 25, 2019 at 11:44 AM Shawn Harris via Gmclist <
> order
> wait?
> Cheers,
> Shawn
> Shawn Harris
> 1977 Palm Beach 403
> North Vancouver,
> Canada
Northern Virginia
No sense, huh? Imagine a pin through a bushing where the bushing supports
the weight of whatever the bushing is in. With any clearance at all, in a
static condition most of that clearance will be at the lower interface of
the pin & bushing, since the weight (and bushing) are "hanging" from the
pin. Fill all the void between the pin and bushing with grease. Now move
the pin in any direction. The grease MUST move from its static
position into whatever space the pin just left. Do it slow & the grease
will move slowly; do it fast and the grease will move rapidly (or
"fastly"). Of course, this assumes the grease has nowhere else to go, such
as along the pin & bushing toward the worn/missing seals. But that's
inevitable and merely reduces the "auto-distribution" I expect rather than
eliminating it.
I'm sure my pins, which were fitted 'way too tightly, with poorly machined
surfaces, have worn the bushings severely, and possibly completely, during
the past 20 years and maybe 120,000 miles, with my greasing procedure. But
they still move freely and APPARENTLY don't have too much lateral play.
The "swing arm" play is controlled by the true-tracks, so I don't notice
it. The coach rides & drives good, so I'm through worrying. :-)
JWID,
On Thu, Sep 26, 2019 at 12:29 PM John R. Lebetski via Gmclist <
> pinching
> evenly distributed.
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Proof of the pudding is in the eatin'. They say. If the back end does not
steer the front, causing the driver to constantly correct for the wind
steer, truck grooves, crown roads, etc. Then I vote for leaving it alone
until it does. Then repair or replace as needed.
If I were designing that rear bogie pin and bushing assembly, I
personally would want the pins to rotate and distribute the wear. Might
want tapered roller bearings in pairs with adjustments, too, although those
bronze bushings can carry an enormous load fitted correctly.
On Thu, Sep 26, 2019, 12:03 PM Ken Henderson via Gmclist <
> eliminating it.
> JWID,
> Ken H.
> > pinching
> > evenly distributed.
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
I'm not sure what's going on, but I can't get grease to go in both lower ball joints! They're only 5 yrs old and damn well acting like it. My gun will
not squeeze. Acts like it's clogged or maybe just a fake fitting. I think they're taunting me.
I've tried jacking it up at the lower control arm, nope.
I've tried jacking it up from the center, nope.
I've tried whispering with a soothing tone that I will not steer into potholes, nope.
I've even tried cracking a cold one and offering it to my homies, nope.
So I just smeared grease around the outside and am hoping for the best.
Sincerely, Confused and Betrayed.
JR Williams
JR Williams
St Petersburg FL
77 Birchaven
Sometimes the zero fittings jam. Try replacing one or both fittings. They are very inexpensive.
-Dave
1978 Transmode near Pittsburgh
> JR Williams
> JR Williams
> St Petersburg FL
> 77 Birchaven
A few years back we (the GMC community) found that the ball in some joints
will touch, and seal, the inner end of the Zerk. Grinding a bit off of the
inner end, and filing a cross slot on the Zerk allows the grease to get
past the ball. This is probably more common than stopped up fittings. Be
sure to flush all the debris from the fitting after working on it.
Let us know if it works.
On Thu, Sep 26, 2019 at 7:34 PM jronguitar--- via Gmclist <
> will
> potholes, nope.
> JR Williams
> JR Williams
> St Petersburg FL
> 77 Birchaven
The fitting threaded portion is so long, that it wedges against the top
plate inside the ball joint. I have encountered this several times. Find a
zerk fitting with a shorter threaded portion, or remove a slight bit from
the threaded portion on the grinder, clean it very thoroughly, and screw it
back in.
On Thu, Sep 26, 2019, 4:37 PM Dave Stragand via Gmclist <
> -Dave
> > On Sep 26, 2019, at 7:34 PM, jronguitar--- via Gmclist <
> gun will
> potholes, nope.
> > JR Williams
> > JR Williams
> > St Petersburg FL
> > 77 Birchaven
Bob Stone had one apart and was explaining it to me over the phone. Perhaps I misunderstood the juxtaposition. I have not needed to work on mine yet
You don't fully understand stuff until you take something apart and put it back together.
Want to give y'all a warm "Thanks a bunch!"
Unscrewed the Fitting on the lower ball joints and away the grease flowed. There wasn't much thread on those zerks to talk about, so I just tightened
them back down.
All is right in the world.
JR Williams
St Petersburg FL
77 Birchaven
I was under the front end today finishing up the CV shafts. Reading this thread I thought I would grease the front end while the coach was on jack
stands, with the front tires off, and a bottle jack under each A arm taking off some torsion pressure.
To me it was MUCH easier to do the upper and lower ball joints. And much better visibility and access to really do it right. And clean up was a
breeze!
That's how I will do it next time. Cordless impact driver really makes short work with the tires.....
Scott
Scott Nutter
installed MSD Atomic EFI
Houston, Texas
