house water system
ron montesi
3
76
hondo
what is causing the pulsing in my water system? sur-flo pump....only using tank and pump , no outside connection. happens in either sink and with
either hot or cold
RM
Erratic or defective pressure switch in the pump or overall system?
D C "Mac" Macdonald
Amateur Radio K2GKK
Since 30 November '53
USAF and FAA, Retired
Member GMCMI & Classics
Oklahoma City, OK
"The Money Pit"
TZE166V101966
'76 ex-Palm Beach
k2gkk + hotmail dot com
Sent: Wednesday, July 1, 2020 16:46
Cc: ron montesi
Subject: [GMCnet] house water system
either hot or cold
RM
Ron,
I've owned 8-10 RV's over the past 60 years. They all suffered from
pulsating water pressure when running on the 12 VDC pump. I found there's
one easy way to correct the situation: Use a surge suppressing
"accumlator" (a small air-charged tank) such as: low.es/3il70VE
Just put a tee in the output line from the water pump to connect the
accumulator.
On Wed, Jul 1, 2020 at 5:47 PM ron montesi via Gmclist <
> with
> either hot or cold
> RM
> with either hot or cold
I had a Monaco Dynasty DP for a while and it did not have the pulsing in the water system because the factory installed an accumulator like Ken said.
It works like the system in a house that has a well pump.
Tom Lins
St Augustine, FL
77 GM Rear Twin, Dry Bath, 455, Aluminum Radiator Quad-Bag Suspension Solar Panel
Manuals on DVD
GMC Dealer Training Tapes
http://www.bdub.net/tomlins/
Ron,
I am unsure what you mean by pulsing.
If it is very high frequency, I have seen this when a triplex or quad pump failed an internal valve. The pulse is very fast two or three times a
second.
I have seen the lower frequency like three or four seconds per pulse and that was just the natural frequency of a system with no hysteresis (dead
band) in the pumps pressure control.
That any help?
Thanks for the info.
> Ron,
> accumulator.
> Ken H.
>> with
>> either hot or cold
>> RM
>> GMCnet mailing list
I find the pulsating worse at partial flow than full flow.
--johnny
Braselton, Ga.
Sure. The faucet acts like the tuning potentiometer in a feedback
Loop oscillator.
John Lebetski
Woodstock, IL
