If you are doing electrical work on your coach, be aware that they are wired with SAE sized wire and NOT AWG. SAE wire sizes can be as much as 10%
smaller than AWG and the voltage drop at high loads can be a real big issue.
Also, if you have to buy much wire, find a marine supplier (not a boat stuff store like West Marine). Marine wire has two significant advantages in
addition to being AWG sizes:
It is finer stranded for both fatigue resistance and easier bending to fit.
It is all tinned strands for corrosion resistance.
The increase in cost is minimal and as I always made note to clients, you only have to buy it once.....
