House Battery connection clean up
> So I have been trying to find the isolators, where did you purchase them? thanks.
> Grant
Grant,
As this is in an electric thread, I assume you mean battery isolators.
There are three easy choices:
Applied will have one
Marine stuff suppliers should have them
Ebay always has a number.
You want to buy one with at least the same rating as your alternator.
I did some research on this when I discovered my isolator went bad and some of the sites were recommending extra capacity beyond your alternator’s
amps. I have a 100 amp alternator so I found a isolator that was 160. It was a big old honking thing but worked great when I hooked it up.
Below is the link to it on Amazon.
TG
DB Electrical BSL0003 160 Amp... https://www.amazon.com/dp/B0081SB7IC?ref=ppx_pop_mob_ap_share
Tom Geiger
76 Eleganza II
KCMO
