While perusing E-bay, I found a "Horn Amplifier". Instead of an air horn or siren, you hook this into a weather proof speaker. The posting is
unclear about what noises it can make. But it does say "Air Horn. If you search online, you can find a switch able version that can make many of the
normal emergency vehicle sounds.
That's all well and good, but I want one that plays several hundred watts of tires braking on dry pavement.....
With the introduction of anti-lock I haven't had a good brake squealer since I got the 87 T-coupe.
Yeah, I can drag the four rear of the coach (its a light 23), but they aren't right at some fools back bumper.
When he cuts in front to make the exit, I want him to miss the exit. Horns, any horns, just aren't the same adrenaline getter.
