After a little web research and a phone call to Evercoat it appears there
is only ONE epoxy based resin system that Evercoat makes. Its called
Everfix and available in quart and gallon kits. It is available at
Wallmart, Oreilly's and other retailers.
Sully
77 eleganza 2
seattle
> Since Evercoat is a polyester compound it does not bond well with SMC long
> term. There is an article in a past issue of GMCMI newsletters that I
> wrote several years back that explains why polyester resins don’t bond well
> with SMC. If anyone needs the link to the article let me know.
> Epoxy is the only resin that will last long term.
> Emery Stora
> 77 Kingsley
> Frederick, CO
> > Ive had good luck with evercoat ( not eastwood ) SMC resin, and the
> Vette guys like it. Besides I have a bunch So I'll be using that.
> > Epoxy may be better, but id rather not buy more since my garage is
> pretty much full.
> >>> I have bought West Systems stuff from Jamestown Distributors. For a
> long time I was intimidated and afraid to try it. I did buy the pumps
> (highly
> >>> recommended). Once I finally got the courage up, I found the stuff
> quite easy to work with. They have lots of helpful how-to videos on their
> site.
> >>> Anyway, lately I noticed Jamestown has been heavily promoting their
> private label "TotalBoat" brand epoxy. Supposedly it is compatible with West
> >>> Systems (as in you can mix/match Epoxies and hardeners). The TotalBoat
> stuff comes in plastic jugs instead of metal cans, has its own set of pumps
> >>> available, but is significantly cheaper.
> >>> Has anyone tried the "TotalBoat"? I have enough of the West systems on
> hand now for several future minor repairs, so see no need to switch at this
> >>> time.
> >> Paul,
> >> Much as I expected, Gougeon knows about Total Boat. The response I got
> from my tech guy was that they have found not bond issues when used with
> West,
> >> but that the components are not compatible.
> >> This is no particular surprise.
> >> Matt
> >> Matt & Mary Colie - Members GMCMI, GMCGL, GMCES
> >> '73 Glacier 23 - Still Loving OE Rear Drum Brake with Applied Control
> Arms
> >> Now with both true Keyless and remote entry
> >> SE Michigan - Twixt A2 and Detroit
> >> GMCnet mailing list
