Finally fired up the engine with the spreadbore Holley installed last night.
Also, having the Autozone(E8012S) fuel pump installed was a great asset. I
switched the pump on to prime the carb and saw fuel pouring out the
secondary spray bars. Two raps with a screwdriver handle unstuck the rear
float and all was well. Then turned the key and she fired right up - no
cranking for 30 seconds waiting for the carb to prime - don't know why I
hadn't done this before.
A couple notes on the pump. It came with 5/16in hose barbs and the fuel
hose on my coach(just downstream from the tank selector valve) is 3/8in.
The pump inlet and outlet are 1/8npt and I as finally able to find 1/8npt x
3/8in hose barbs at Discount Auto Parts. Also, the price for the pump at
the Riverdale, GA Autozone was $32.99 instead of the $26.99 posted here.
Currently have the pump wired for prime and emergency use only with an amber
lighted switch off the ignition lead. I'll probably re-wire to add a
push-button for priming and wire the switch off the alternator output(fused
of course).
I was able to install the Holley without a spacer, but had to modify the
linkage lever on the carb to do it. The Holley is slightly taller than the
Qjet and I'm currently using an air cleaner off a 77 Toro(HEI ignition),
which is slightly higher than the OEM air cleaner. I'm still scratching my
head as to what to do with the engine cover. I may try modifying the OEM
air cleaner to clear the HEI distributor to gain back some clearance.
Haven't done a road-test yet and will post my impressions after that.
I'll try to post the pic's this weekend.
Patrick
of course).
Patrick
