Well, found out some interesting things this week-end when I de-winterized my 73
Sequoia. Mind you, I've never used a self contained RV before, my VW Westfalia
has an air-cooled engine, icebox and no bathroom (at least indoors). Most
important thing I learned was to turn off the toilet water inlet on my electric
re-circ toilet. I was treating it like the shut off valve in my house (always
on). So I spilled some water. Next the
bathroom drain backed up a little. The holding tank gauge read only half full.
I then noticed a strong smell of toilet chemical coming from the
lower cabinet next to the wardrobe closet (I have a 26 ft. with wardrobe and
column of drawers across from the wet bath). Looking down where the
sink drain enters the holding tank I notice lots of wetness. Seems the fitting
that goes into the holding tank broke off at some point and somebody
caulked it up but the caulk broke loose.
I did complete adding a tranny oil temp gauge, oil temp gauge, tachometer, and
voltmeter. Next will be a radiator rock guard. Only three weeks to my Myrtle
Beach trip and 7 weeks till our cross country trip. Lots to do.
Any suggestions on how to get a water tight seal from the sink drain into the
holding tank? Not much room to work, maybe I'll open up the hole
where the piping runs down to the holding tank. I'd like to try and fix this
in-situ before I have to remove the holding tank. Any suggestions on the
gauge for the holding tank? Always seems to read 1/2 full (or 1/2 empty
depending on whether your an optimist or pessimist).
eric.henning
73 Sequoia
eric.henning
73 Sequoia
