Hitch
peter brandt
743
Arch,
Thats what the PO did on my coach. I'm pretty sure he relocated/extended the
dump tube. Looks like a pretty clean installation.
I'll go out there and take some pictures for you.
Peter
Colorado
To:
Sent: Saturday, April 01, 2000 9:57 AM
Subject: GMC: Hitch
> GMCers
> Next question: I would like to put on one of the through the bumper
> hitches. Right now I think mine is a stock setup. My question is
> if I put on a through the bumper am I also going to have change
> the dump tube. I do want to put on a macerator pump someday--
> just not so soon. TIA
> Take Care
> Arch
Arch,
Somewhere on the net there are pics of the through the bumper hitch
installation. Someone out there maybe knows the location. I'll look and
send it to you if/when I find it.
Roger
Do the macerator... it will make a world of difference. Go to gene's
site and see some of the ways you can do one. I like the way mine came
out.
al
> GMCers
> Take Care
> Arch
Arch,
I'm sending you the hitch/dump tube pictures private e-mail, just got my
digital camera last week and haven't had much time to play with it yet. I'll
start a PhotoPoint GMC album and post more GMC pictures once it's all
cleaned up and back together - it's a mess right now.
It sounds like the macerator is the way to go, just too many other projects
for me at the moment. So this is the way the coach came and I'll live with
it for now. I don't know what the original dump tube looked like, seems like
they just added a couple of elbows.
I can't find any information on the hitch in my paperwork-
I like the way it bolts to the frame though, looks like a good fit.
Good luck,
Peter
Colorado
To:
Sent: Saturday, April 01, 2000 10:42 AM
Subject: Re: GMC: Hitch
> In a message dated 04/01/2000 11:30:56 AM Central Standard Time,
> Peter
> Thanks. Sorry for the compressed time frame. I am just in a hurry now.
> Take Care
> Arch
Arch, I put my hitch thru the bumper but my 3" sewer system has been
totally removed.
IMHO, the very first change anyone should make on their GMC is the
macerator. Nothing else will give you a bigger satisfaction return for
the buck!
David Lee Greenberg
GMC Motorhome Registry
Dedicated To The Preservation Of The GMC Classic!
www.gmcss.com/registry.htm
No, you do not have to do the pump now. You can add, like I did, a second
valve which would be used on the macerator. Then just put your drain
wherever you want off to the side.
al
> In a message dated 04/01/2000 11:43:26 AM Central Standard Time,
> > He has a through bumper hitch, toad pulling attachment, and
> > has made the macerator change.
> Scott
> Thanks. I know he did the pump. My question is do I have to do the pump
> now?
> Take Care
> Arch
Arch
I have a through the bumper hitch and it did not change the original dump
system. Now I also have the Macerator but that is documented ;>)
I do not know if mine was built or where it came from so I guess if you
know it can be done is half of the battle
gene
>totally removed.
>the buck!
> David Lee Greenberg
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
Arch,
Did you get my hitch pictures?
Peter
Colorado
To:
Sent: Sunday, April 02, 2000 6:41 PM
> In a message dated 04/02/2000 7:17:43 PM Central Daylight Time,
> Gene
> THANK YOU! That is what I wanted to know. I will do the hitch
> thing then do pump when it comes up on the list. Thanks again.
> Take Care
> Arch
Arch,
Just sent the pictures again - I hope you get them this time.
I also put them on PhotoPoint:
http://albums.photopoint.com/j/AlbumIndex?u=180485&a=3863156
Good luck with your installation!
Peter
Colorado
To:
Sent: Sunday, April 02, 2000 9:28 PM
> In a message dated 04/02/2000 9:26:16 PM Central Daylight Time,
schaf
> Dont think so. Try Gcbr
> Take Care
> Arch
Arch,
Looks like they added at least one elbow, the pipe attaches just to the
right of the hitch in the "up" position.
Peter
Colorado
To:
Sent: Monday, April 03, 2000 5:50 AM
> In a message dated 04/02/2000 11:37:31 PM Central Daylight Time,
> Peter
> Did you have to change the drain? Guess that is why there are white
> elbows. Thanks.
> Take Care
> Arch
