Hitch mounted Motorcycle - Scooter carriers
Hmmm...I'm not so sure about that "...back axle...fulcrum...". More
accurately, I think, the "rear axleS" act as a fulcrum. That is with the
OEM air bag distributing load between the center and rear wheels, causing
the actual "fulcrum" to lie at the bogie. With my 4-bag, or a Quad bag
suspension, the fulcrum would move aft from the bogie toward the rear as
the down force increased.
At least that's how it seems to me off the top of my head at this time of
night. :-)
On Tue, Nov 14, 2017 at 1:38 PM, John Phillips
wrote:
> Keith, you are correct. The back axle does act as a fulcrum and load
> applied to the hitch does remove weight from the front wheels. I was in the
> method of calculating the mode. Sorry.
> When doing the calculations in effect you do two torque calculations. The
> distance from the front axle to the hitch in feet multiplied by the
> tongue weight gives a value in foot-pounds.
> Divide the foot-pounds by the wheelbase in feet to come up with the force
> in pounds the rear axle must exert to support the tongue weight.
> Clearly we need a center mount receiver, 1/2 way between the axles......
​Which is approximately what an "equalizer hitch" provides. You just need
to incorporate another wheel aft of the added load to act as the new
fulcrum. :-)
Given all this load problem, please tell this non-cyclist why you don't
just use a "cradle" in the receiver for the cycle's front wheel and let the
cycle's rear wheel tag along on the ground bearing most of the weight. I
know such devices exist, I just don't know the pros and cons of them.
The cons are a few.
1. Try backing up one of those when you can not see it.
2. Wear and tear on the motorcycle tire and drive train.
3. It gets filthy with road dirt and debris.
The other con is the angle of the bike steering stem does not match the swing angle of the rear of the RV, so sometimes it will slide the rear tire
sideways instead of pivot at the stem.
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
> I use a similar rack (from Princess Auto) - it works OK for a light scooter.
> I'm amazed at how much weight some people carry on their GMC's - I switched last year from a ~230 pound scooter to a ~290 pound scooter and really
> noticed an undesirable change in the overall handling. I can't imagine putting my BMW GS back there!
> Rob
> Victoria, BC
> 76 Royale - Rear Twins/Dry Bath
> > I have been using this cheapo with my through the bumper hitch from Applied
> > https://www.amazon.com/gp/product/B014VC5H64/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
> > Works great for my Honda Big Ruckus 250 (480 lbs)
> > Good luck !
> > Dutch Marc
> > 1973 26' Canyon Land (Mello Yello) (TZE063v101302)
> > Los Angeles, CA ('98 NL 2 USA)
Hi Rob, any chance you have a few photos of your set up?
Thanks for the response,
Mike
Hmm...I don't think I'll use one of those when I take up cycling. (Which
ain't gonna happen until after SHE's gone!) :-)
Ken Burton
10:35 PM (11 hours ago)
to gmclist
The cons are a few.
3. It gets filthy with road dirt and debris.​
Ken, Ken, Ken......... Have you forgotten that the one who goes last has
to dispose of
all the "stuff". Three or four rollback dumpster containers would be
expensive and
a lot of work to fill. Go first and get the last laugh. LOL
Gary Kosier
77PB w/500Cad
Newark, Ohio
Sent: Wednesday, November 15, 2017 9:53 AM
To: "GMC Mail List"
Subject: Re: [GMCnet] Hitch mounted Motorcycle - Scooter carriers
> Ken H.
> Ken Burton
> to gmclist
> The cons are a few.
> 3. It gets filthy with road dirt and debris.>
>> tire
Oh, that's definitely my plan! Which makes my cycling days likely to be
rather limited.
On Wed, Nov 15, 2017 at 10:45 AM, Gary Kosier
> to dispose of
> expensive and
