Greetings, I'm a lurker coming out from under the trees (with pine sap to
show for it).
A major brake job has stalled out for over a decade due to my inability to
bleed rear brakes. The culprit seems to be the master cylinder(s) (new P30
Napa NMC M2219) The front discs bleeds beautify, the rear brake side
refuses to have enough pressure/flow to purge the air. I've purchased 3
master cyls so far & have tried bleeding them;
1st mounted, 2nd bench bled, 3rd pressure bled bench. All with the same
results, the front cylinder/rear brakes never get enough pressure to push
my finger off of the outlet.
Complicating the project is the scope of the project so far it has entailed
the following parts; rotors, pads, larger rear wheel cylinders, SS rear
hoses, brake shoes, all the brake lines and the 3 masters. Thanking you in
advance.
Greg Jankowski
Wheat Ridge, CO
73 23 CanyonLands
show for it).
advance.
Greg Jankowski
Wheat Ridge, CO
73 23 CanyonLands
