Hi again, but need some help
tmaki
757
It's been a while since I was an active participant, but I've kept up
with the list for the whole time. Just haven't been goofing around with
the GMC except to run it once a month or so, and put a few inches on the
new tires moving it around the driveway. Too busy bulking up the
retirement investments. Now that I have crossed the threshold of my
Biblical allotment of time, I figure it's worth getting back to the GMC
projects.
I have an urgent problem for which I can't remember the solution. And
combing through the hundreds of thousands of archived words from the
list and other sources just doesn't seem like fun. So here goes -- I'll
try to keep the syllable count as low as possible (I won't go into the
detail with each item).
-- I have both electric (EP) and mechanical (MP) fuel pumps (plumbed in
the "classic" way, electric pushing through the mechanical). I use EP to
prime carburetor (that's another project).
-- Last time I ran the GMC, engine missed and sputtered and puked out
horrendous smoke. Turned off (but probably not quickly enough) - hasn't
been run since.
-- Thinking EP punched a hole or tear in MP diaphragm, I drained oil.
Yielded about 2-1/2 gallons of lovely gasoline-scented oil (or was it
oil-tinted gasoline?)
OK, GMC veterans know the story. I'm replacing the MP this weekend.
That's not the problem. What I need is a plumbing arrangement to bypass
the output of the EP around the MP. I seem to recall some years ago
someone had come up with a solution. I've sketched something out using
tees and a couple of check valves, but the routing would do Rube
Goldberg proud.
I'm open to suggestions. I would love to have a dual electric setup, but
that is not in the cards right now. I need to get this engine running at
least as well as it did before (which was actually quite good). With
115,000+ miles, I may be looking at some other major fixes, so the fuel
pump luxury will have to wait. How I miss the music only an Olds 455 can
make.
So, there you go. I'll take whatever medicine is prescribed, although a
Ron White quote might be appropriate.
Sidebar note: I occasionally get requests for the Onan maintenance video
with Duane Simmons. It is still available, and will be as long as I have
the digital master.
Thanks for any help. I'm glad to be able to participate again with the
GMC family.
Toby "sure hope my engine isn't hosed" Maki
73 Glacier 230
Riverside, CA
Hi Toby
Wow, so glad to see ya posting again. Been way too long.
I went totally submerged electric so don't have anything to offer ya. Just
so glad to see ya back!
bdub
On Thu, May 21, 2020, 7:27 PM TMaki via Gmclist
> projects.
> been run since.
> Goldberg proud.
> make.
> the digital master.
> GMC family.
> 73 Glacier 230
> Riverside, CA
Toby,
Mine is set up like yours. I know it's not ideal, but I'm hoping that with a fresh mechanical pump on the engine, with hopefully ethanol resistant
diaphragms, I will be safe. I have heard of this happening but have never experienced it in any vehicle I have had with a pusher electric pump on it
(several). I think a ruptured pump diaphragm is really rare.
I haven't had time to think about it, but I can't think of a way to do it with check valves while still maintaining the function of the mechanical
pump.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
I can tell you what I did.
Elect pump with a cockpit switch for starting only. Once she fires I turn
off the elect pump. The mechanical pump takes over. If there is a burp
while under way I click on the elect pump. This way the elect pump is only
used for starting or in an emergency (vapor lock). I have two rollover
switches installed in series with the elect pump. If we are ever in an
accident and the elect pump is on the rollover switched should cut the fuel
supply to the engine.
Len and Pat Novak
1978 GMC Kingsley
The Beast II with dash lights that work and labels you can see!
Fallbrook, CA new email: B52Rule
http://www.gmcmhphotos.com/photos/showgallery.php?cat=4375
www.bdub.net/novak/
From: Gmclist [mailto:gmclist-bounces] On Behalf Of TMaki
via Gmclist
Sent: Thursday, May 21, 2020 4:32 PM
Cc: TMaki
Subject: [GMCnet] Hi again, but need some help
projects.
been run since.
Goldberg proud.
make.
the digital master.
GMC family.
73 Glacier 230
Riverside, CA
This email has been checked for viruses by AVG.
https://www.avg.com
I have exactly the same set up as you do. Yours is only the second person I have ever heard of that had a verified diaphragm failure. Every low wing
gasoline airplane that I have ever seen uses the same arrangement.
In the GMC I use the electric pump prior to start up primarily to hear it run while the coach is quiet, and then next to never for running down the
road. In the airplane we turn on the electric fuel pump prior to starting and read the fuel pressure. Then we shut it off and start the engine.
With it still off we let the engine warm up and taxi out to the runway. On take on we run the electric pump until reaching a few thousand feet and
shut it off for the remainder of the flight.
So in both cases we only use the electric as a back up emergency device. Doing it this way pretty much eliminates your chances of putting much fuel
in the crankcase.
We could design something with a few check valves and reworked gas lines, but by the time we got done you could have spent the money on a second pump,
an oil pressure switch, and a block off plate to cover the hole where the mechanical pump was. So if that is what you want, just go to a two electric
pump system. There are many different ways to plumb and wire it.
Thanks Carl for sharing that. I remember you mentioning in the recent
fuel pump thread that you have this setup. Over the years I've read a
number of cautions re: the possibility of MP failures resulting from the
EP pushing through. The pump failure itself isn't that big a deal. It's
the flooding of the oil pan with gas that ruins your day.
Your experience with never having had this happen gives me confidence
that perhaps it's a statistically far outlier.
I've seen your beautiful GMC at a couple of rallies and, I think, out at
Quartzsite some time back. I'm pretty sure you wouldn't jeopardize it
with a compromising setup.
Thanks again.
Toby Maki
73 Glacier 230
Riverside, CA
> pump.
Thanks Len.
That's what I do, although I've never had a vapor lock problem. I use
the EP only to get gas to the carburetor (separate switch). I turn it
off even before cranking the engine. It usually only takes a few seconds
to fill the carb bowl. When the sound of the pump changes, I turn it
off. I guess my first clue to something being wrong was a much longer
prime time -- actually, the sound really never changed like it always
had. Hmmm . . .
Well, at least I've found another use for two of my best diagnostic
tools -- my ears. (Memo to self: "Listen to that pump.")
Thanks again, Len. I appreciate your thoughts.
Toby Maki
73 Glacier 230
Riverside, CA
Thank you for the compliment Toby.
I actually do not use the electric pump very much. Usually I switch to the aux tank, activating the pump before starting, to prime the carb, then
switch back to Main. I generally only use it to help with vapor lock type symptoms while driving up a long grade in the Summer time or when I let my
main tank get too low.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Thanks, Ken, for your thoughts.
I run my EP just like you do. Sitting quiet, I can hear the pump and its
changing sound when the carb is full. And, like you, I don't run it
while driving.
Your comments re: airplane use is encouraging. I don't remember the fuel
plumbing details of the Piper Cherokees I flew 35 years ago, but what
you describe sounds familiar.
And you're right -- cobbling up a piping system would not be time or
money well spent at this time.
I'm feeling a lot better about this. I have to consider that I bought
this GMC from the original owner 21 years ago. He had put on the EP and
run it for years before he sold the coach to me. So, although not
perfectly fail safe, it is generally reliable.
I'm going to carry on with it this weekend. After I clean up the spark
plugs and do the filter/oil drain and refresh, I'll give it a try.
Hopefully, all will be well.
Next, I've got to replace the dipstick tube. Got a new one from Jim K.,
but have to get the old one out first. (I feel a Roseann Roseannadana
moment coming on . . . )
Thanks again.
Toby Maki
73 Glacier 230
Riverside, CA
Going to the Pacific Cruisers rally next month?
Len and Pat Novak
1978 GMC Kingsley
www.bdub.net/novak/
via Gmclist
Sent: Friday, May 22, 2020 9:21 AM
To: Len Novak via Gmclist
Cc: TMaki
Subject: Re: [GMCnet] Hi again, but need some help
Thanks Len.
had. Hmmm . . .
Toby Maki
73 Glacier 230
Riverside, CA
only
https://www.avg.com
> It's been a while since I was an active participant, but I've kept up with the list for the whole time. Just haven't been goofing around with the
> GMC except to run it once a month or so, and put a few inches on the new tires moving it around the driveway. Too busy bulking up the retirement
> investments. Now that I have crossed the threshold of my Biblical allotment of time, I figure it's worth getting back to the GMC projects. (See
> Response #1 below)
> I have an urgent problem for which I can't remember the solution. And combing through the hundreds of thousands of archived words from the list
> and other sources just doesn't seem like fun. So here goes -- I'll try to keep the syllable count as low as possible (I won't go into the detail
> with each item).
> -- I have both electric (EP) and mechanical (MP) fuel pumps (plumbed in the "classic" way, electric pushing through the mechanical). I use EP to
> -- Last time I ran the GMC, engine missed and sputtered and puked out horrendous smoke. Turned off (but probably not quickly enough) - hasn't been
> run since.
> -- Thinking EP punched a hole or tear in MP diaphragm, I drained oil. Yielded about 2-1/2 gallons of lovely gasoline-scented oil (or was it
> OK, GMC veterans know the story. I'm replacing the MP this weekend. That's not the problem. What I need is a plumbing arrangement to bypass the
> output of the EP around the MP. I seem to recall some years ago someone had come up with a solution. I've sketched something out using tees and a
> couple of check valves, but the routing would do Rube Goldberg proud.
> I'm open to suggestions. I would love to have a dual electric setup, but that is not in the cards right now. I need to get this engine running at
> least as well as it did before (which was actually quite good). With 115,000+ miles, I may be looking at some other major fixes, so the fuel pump
> luxury will have to wait. How I miss the music only an Olds 455 can make.
> So, there you go. I'll take whatever medicine is prescribed, although a Ron White quote might be appropriate.
> Sidebar note: I occasionally get requests for the Onan maintenance video with Duane Simmons. It is still available, and will be as long as I have
> the digital master.
> Thanks for any help. I'm glad to be able to participate again with the GMC family.
> 73 Glacier 230
> Riverside, CA
Toby,
#1 - You should at least stop and say hello once in a while.
#2 - Your engine is most likely unharmed. But, you will want to change the oil twice after you replace the engine's pump. The first is just to put
good oil in it and the second is to get any remaining alcohol from the fuel out of the engine.
#3 - As long as it is a digital master, you should pick someone to pass a copy to so it is not lost in the case of some disaster.
Not an actual question, but a response to what you may be doing.
If you are starting any engine on an irregular basis and not running it loaded to get to full operating temperatures, you are much better off leaving
it alone. This is particularly true of little engines. They are much better off if the gas is run out of or drained from the carburetor. If you
don't know how long you might be leaving it, learn how to "fog" the engine.
And one silly question... Is your Glacier a White Glacier or a Blue Glacier. Something I read said that the blue did not sell well in either 23 or
26 and there may have been fewer than a dozen 23s in blue.
Yeah, that's probably true. Just haven't had anything to contribute.
Besides, I can't compete with the width, breadth, scope and fascination
factor of many of the topics posted  :-)
That's the plan. Just going out today to get 12 qts of new oil and two
more filters. Glad to hear that my engine is probably OK.
> it alone.
Mea culpa, mea culpa. But it's a little like me and my cello. I can't
play it in any way describable as music, but not getting it out once in
a while to at least tune it and play a scale is better than looking at
it in the corner. On the other hand, the last time I got it out, I broke
a string, split the bridge, and lost all the hair in the bow. Hmm . . .
gotta be a lesson in there somewhere.
> And one silly question... Is your Glacier a White Glacier or a Blue Glacier?
Blue. S/N 837. Ooh, ooh maybe it's got rarity value (?) . A little like
a YouTube I saw this morning about the Chevy HHR SS. Only 216 or so
built -- folks asking $15,000 for a $3000 car. Naaahh!
Toby Maki
73 Glacier 230
Riverside, CA
> > to put
> That's the plan. Just going out today to get 12 qts of new oil and two more filters. Glad to hear that my engine is probably OK.
> Toby Maki
Toby,
Don't bother with the filters. Just dump them between changes. If you are still concerned, find a local speed shop that has a filter cutter (they
are a bear to open with normal tools) and take the last filter to them. If it is full of silver flakes, I was wrong. (Hint, it won't be.)
I'm not a member of Pacific Cruisers. Actually, I think I let my Western States membership lapse. So, no not this time. I'll have to get my WS membership up to date.
TM
>From: Len Novak
Good tip. Thanks.
TM
>From: Matt Colie via Gmclist
Almost any airport mechanic will have a filter cutter. We open them all the time.
