As I am fully in play mode with solar now, ALL my figures are created in hourly segments unless otherwise stated.
I created many Exile worksheets to play with the numbers, and I will admit I am not perfect but I am getting some
pretty good numbers that compare to working systems.
My original comment was an attempt to help the user understand that SOLAR is a balancing act between the panels, batteries and the load.
One scenario is where you may have a high count of solar watts which allows you to run some appliances during the sun hours
while the batteries maintain charge.
Another scenario is where you charge the batteries during the day and use the battery storage in the evening, requiring more batteries.
The scenarios go on and on, it is all a customizing game to the use you have for the system.
No one system is the same.
My only comments on the batteries is they need something charging them, solar, vehicle alternator, generator or all of the above.
Recent reads have come up with information that says that even though you CAN use the power in a battery and run its level down, IDEALLY, you want
your battery levels high, near full.
We had lead acid batteries in battery banks that would last 25 years.
the Lithiums, and i am not going to get into an argument over these new batteries, but they have concerns that no one seems to
consider. All that is heard is they can last longer and discharge further. I will say that is true, but, they don't like
that deep of a discharge and every deep discharge is taking some life away from the battery.
Also, NO BATTERY likes High loads for extended periods. Besides shortening the life of the battery, extreme high loads will find your
system weak spots, usually connections, and they will get hot or burn. That is why I mentioned that time measure formula some kind
person offered here at GMC net at one time, it is a loose figure to work with,
but it is close enough to get an idea of what you are working with.
IDEALLY, the batteries like low loads of 5 to 10 amps. You start to get high loads from the batteries, you need more batteries
to share the load.
Running the inverter is expensive on your battery power. at 12v dc, its a factor of 10. 20 amps of 12v dc into the inverter
will supply 2 amps of 120v AC. The normal roof top AC is plus or minus about 9 amps, which would be 90 amps from the battery/hr.
So that is not likely to happen as physically, the GMC does not have enough roof for panels or space for batteries to support that.
The RV Nomads have taken to home windows units which run at about 3-4 amps/hr to run. This translates to 30 to 40 amps of 12v dc into
the inverter, still requires an extra panel or two and one or two more batteries, but it can be done.
One important thing to keep in mind is if you draw high amps from the Lithium batteries, they start to get hot. That should be a warning
but most just ignore it. The article I read said that if those components, and that chemical mix begins to ignite, that battery
fire is very difficult to put out, and you cannot use water on a lithium battery fire. If the fire department finds out there are
lithium batteries involved in a fire, they become much more cautious about attacking that fire. So much so you may lose your rig.
This is the main reason that batteries, including Lithium batteries, should be planned to supply low current loads, within reason, to the system
including the inverter.
Keeping the current loads down extends the battery life and runs at a much safer operating margin.
For myself, my rig sits over winter so Lithiums do not fit the plan for solar storage because of temperature..
My batteries are and will be some form of lead acid, probably gel because lead acid can handle much more abuse over the lithiums.
Talking about batteries these days, especially with the lithiums out there is dangerous because people form their opinions and once they set their
minds, there is no changing them. Lithium batteries have more or less morphed 2twice that I know of now and the rules have changed. They are not the
magic cells that people talk about and require very similar care and use that the Lead acid cells do.
The Lithium cells are one area that I have kept an eye on and read the articles so there is a lot to learn about them. In some ways they can
be more dangerous than using Lead Acid, but most won't understand this until something bad happens. and we move forward.
GatsbysCruise. \
Waukegan, Illinois \ Keep those MiniDiscs Spinning \ MY GREYHOUND IS FASTER THAN YOUR HONOR ROLL STUDENT \
WindowsXP-Win7-Win8.1-UBUNTU STUDIO -
