The foam that is referred to here ----- where can I get it in quantity
(like the factory used), not just a can at a time????
>Hi Henry!
>On my 1975 PB the underside of the floor (roadside) is covered with 1" foam
>and thin alu. skin. If your plan is to just drill right through the floor
>and washer underneath, the foam might not have the compression strength you
>are looking for and eventually make the fastening of the seats loosen up.
You
>could use a 1/4 drill first as a pilot hole and then use a hole saw from the
>bottom to cut alu and foam away. That way the washer/nut and bolt would be
>against the plywood and less compression. Then patch the underside holes.
>Just some thoughts!
>Scott Underneath
>your GMC
>Hi Henry!
You
>Just some thoughts!
>Scott Underneath
>your GMC
