Help
yes on water,yes on power,yes on generator, I don't know what a by-pass kit
looks like, how hard is it to get a water heater out to check the other
things you ask.
> A few questions:
> 1. Do you have water flowing from both hot and cold faucets ?
> 2. Do you have power at wall outlets ?
> 3. Have you tried with generator power ?
> 4. Is there a by-pass kit installed on the water heater for winterization ?
> The GMC Motorhome uses a 240V plug that splits into two circuits.
> Normally the water heater will operate when using an adapter to a 15AMP
> plug , but
> I have experienced adapters that power the Air Conditioning circuit.
> If you are experienced working with AC Power, use your volt meter to check
> to make sure the heater is getting power. If not, you have a problem in the
> AC wiring.
> If you are getting power to the heater the problem is either the
> thermostat ( on the heater), the element, or the wiring in the heater. Use
> your volt
> meter to determine.
> Good Luck ! Let us now what you find.
> Carl Harr : Driver NASCAR Pro Series #2
> 1978 Gadabout-Restoring
> 1978 Palm Beach
> 1976 Glenbrook
> Prevost Featherlite H3-45
> http://temp.gmcnet.org/cgi-bin/mailman/listinfo/gmclist
*Thanks *
*Bill Ezzell *
That would be 12.5 Amps, NOT 12.5 Ohms, giving 9.6 Ohms for the resistance.
Mac in OKC
Sent from my iPad
> Nooooooooo
> Be nice
>> Rob,
>> We don't what he checked continuity with....
>> If it was a "Free at Hazard Fright" VOM, it may look like continuity as
>> opposed to open.
>> Matt
>>> Bill,6
>>> Something is wrong, you should not get continuity when you check the
>> heater element.
>>> IIRC the element is 1500 Watts divided by 120 Volts equals 12.5 Ohms.
>>> Regards,
>>> Rob M.
>> Matt & Mary Colie - Members GMCMI, GMCES
>> '73 Glacier 23 - Still Loving OE Rear Drum Brake with Applied Control Arms
>> SE Michigan - Twixt A2 and Detroit
>> GMCnet mailing list
> Gene Fisher -- 74-23,77PB/ore/ca
> “Give a man a fish; you have fed him for today --- give him a URL and
> http://bdub.net/gmcmotorhome.info/
> Alternator Protection Cable
> http://bdub.net/gmcmotorhome.info/APC.html
Mac,
Oops!
Naturally you're correct, don't know how I screwed that one up, sorry!
Regards,
Rob M.
-----Original Message-----
Mac in OKC
William , here us a link to the maintenance manual, there are complete instructions on checking and removal of the water heater. Look in section 24
I suspect the problem is in the heater components but you might want to have someone familiar with household wiring confirm that there is power at
both sides of the the on/off switch when it is in the on position. If not, the problem could be the on/off switch or circuit breaker.
http://www.gmcmi.com/wp-content/uploads/2014/05/X7525_75-76-maint-manual.pdf
1978 Palm Beach
1976 Glenbrook
Thanks for the link
> 1978 Palm Beach
> 1976 Glenbrook
*Thanks *
*Bill Ezzell *
