Heinz--
Mine is the Ragussa slide tray mounted to the plywood floor boards (lined the
floor with aluminum first). I find this arrangement completely satisfactory
- --easy to use and holds my two golf cart batteries OK. All I had to change
was to add a little longer battery cable to allow the tray to pull all the way
out. If you want a picture I can take and send one as soon as Anderson
finishes my 6-wheel Harrison brake conversion.
Gary
North Bend, Oregon Coast
> Did you build it Gary or find/buy it?
> Heinz
> > >I have one and it works great. Now it is easy to check the water level
> > >on my 2 golf cart batteries --- something that I neglected to do before
> > >the tray. Gary
> > Ok...
> > Regards,
> > John 74 Glacier
