HELP NEEDED 60 KM SOUTH OF NORTH BAY ONTARIO
Or, to finish the trip, grab both halves of the connector and wiggle them.
That's be good for now.
> Typically the inside panel is not a point of failure. There is a plug
> located behind the generator by the frame rail that is the wiring from the
> panel to the generator. This plug has corrosion issues and will cause the
> symptoms that you suggest. If the plug is still present I would suggest
> that you cut the plug out of the lines, ONE WIRE AT A TIME! Use some
> connectors and or butt splices and then tape to protect the wiring.
> > ANOTHER UPDATE ...
> > Shortly after the (supposed fuel) issue arose the coach fired right up
> and has been running for approximately 20 hours without issue, from North
> Bay, Ontario over the northern tip of Lake Superior beyond Thunder Bay
> closing in on Manitoba.
> > The latest issue is the generator won't fire up from the inside panel...
> not a sound, not turning over or anything?
> > Any ideas what to look for, it was running fine when they stopped for
> the night (Tuesday), I guess there was no need to start it yesterday but
> today nothing?
If you can pull it out and start it from the switches on the board then we know the problem is with the remote start panel only.
The most common failure with the remote panel is a poor connection of the remote panel cable to the Onan. The connection near the rear of the Onan
gets dirty and then the switches fail. I cleaned mine up once about 15 years ago. I'll look on the photo site and see if I can find any pictures.
Thanks for your help Ken, really appreciate it. Look forward to the photos if you can find them, in the meantime I shall forward your suggestion.
Mike
I should have said that cable is a 5 conductor one and the plug has 6 positions. I'm looking for a picture.
Just another point of note with the Frame rail connector and ROYALEs. The wiring colors dont match the wiring schematic. They were different when
Coachman wired up the inside panels. As suggested Cut and Splice ONE wire at a time.
Mid Michigan
77Royale - thank you as well for confirming the potential wiring issue, I will forward this along.
Mike
I forgot that is a Royale. They are different.
Yes, you may find that harness wired several different ways. Those guys at
Coachman were hired based upon their ability to fog a mirror when they
exhaled upon it. Always a mystery on plumbing and wireing.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
Possibly,
I do not know how a coachman is wired. Does it have a separate starting battery or does it use the house batteries to start?
All GMCs are separate. And some Coachjmen and Norris wiring is a real challenge. Hare n Hound is Your Friend.
