> I've done several HEI conversions. The nice thing about HEI is
> that there's only one wire to run.
> First get a roll of red #10 AWG wire. The HEI draws quite a bit
> of current. With any smaller wire, you will get too much IR voltage
> drop.
Wouldn't 10AWG wire be overkill for this, as it would be good for some
30a. I imagine 14AWG would be more than adequate(10a). There should be
insignificant voltage loss if the wire is sized properly and connections
well made. The sheer weight of 10AWG wire would put a lot of strain on
the connections if not properly supported.
> Pirate an HEI "batt" terminal pigtail from a late model GM car.
> That's the one that plugs into the distributor cap and has a clip on
> it so it cannot come off. I just get them from the junk yard. Cut
> off enough wire to splice to your #10 wire.
> Run the #10 wire inside your coach and over to your fuse box.
> Splice a 1/4 inch spade terminal onto the other end and plug it
> into the "ign" terminal in the center of your fuse box. That's all
> there is to the hook up. Don't worry about putting a fuse in
> the circuit. It doesn't need one. The module is "self fusing".
A fuse is not only to protect the device, but also to protect the
wiring. Every circuit except the primary cables connected to the
battery should be fused. Running a 10AWG wire through the firewall
without fusing could result in a fire should the wire short out
anywhere along its length. I would definitely use a fuse sized to match
the wire gauge(10a in the case of 14AWG).
Otherwise, I agree with Scott's outline of the procedure.
Patrick
Patrick Flowers
Mailto
atri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
> drop.
Patrick
Patrick Flowers
Mailto
