It does come out the front and any competent radiator repair facility should be able to clean and repair it.
> No, we are not. Thanks for the offer.
> It hasn't failed but got a lot of green staining around it and while redoing all the ac/heater motor and switches, thought I might change it out.
> I saw in the parts list that Four Seasons # 94530 is suppose to work, but I don't know if it a drop in as I don't know the dimensions of the
> original or the suggested replacement. The inlet and outlets don't have the fancy turns in them like the original but they are bent in the same
> direction.
> Just wondering if it is the same core dimension as the original or if that matters at all.
> Then there is the problem of getting it out, does it come out from the outside or do you have to tear the dash apart to get it removed?
C. Boyd
76 Crestmont
East Tennessee
