>I'm trying to remove the evaporator and the heater core. I'm doing it because
>of low air flow at the outlets. I thought maybe the evaporator was plugged up
>and if I could get it out I could clean it. It looks like you could swing it
>out a little and clean it if the hoses are flexible enough. I'm having a
>little trouble getting the screws out that hold it in. I also thought I'd
>take the heater core out and have it checked while I'm in there. Seems I'm
>having trouble getting the screws out of it's brackets! The one on the
>driver's side just seems to keep turning without backing out and I am having
>trouble getting a socket on the ones on the passenger's side. Me and my
>bright ideas! They often get me in trouble. Can someone give me some
>pointers????????
>TIA
>David
David - can you get a small vise grip on the head and pull while you
are turning. This may start the thread. Also, if its a little loose
you might be able to wedge a flat blade screwdriver under the hear
while you try to turn it with another screwdriver. Last resort, get
a cold chisel and knock the head off and take out the screw from the
other side after you get the core out.
Emery Stora
77 Kingsley
Santa Fe, NM
>pointers????????
>TIA
>David
Emery Stora
77 Kingsley
Santa Fe, NM
