heads
robert teed
170
"While the above problems only become critical on race motors, valvetrain
deficiencies manifest themselves practically every time a cam is changed,
the block and heads are milled, or a simple valve job is performed. In stock
form, the Olds valvetrain is non-adjustable, so no tolerance exists for
changes anywhere in the system. For example, since the common everyday valve
job moves the valve seat higher up into the pocket, the valve stem height is
effectively increased, often upsetting the valvetrain geometry
(knowledgeable Olds head shops can compensate by slightly reducing valve
stem length). To permanently correct these problems, there are several
solutions. They are (from cheapest to most expensive): shimming or milling
the rocker arm pedestals, installing adjustable pushrods, or converting to
adjustable rocker arms by the use of a bolt-on aftermarket kit. The latter
solution is really the most practical."
I read this on the Olds FAQ web page listed in an
earlier post. That is a really great site...
Anyway, I guess if I have My Heads milled,Etc.
Then I'll have to be sure the Machine Shop is
aware of this....
I love the Net...If it werent for sites like these
I would just bolt this stuff back on and have money
left for Beer!
Gota go raise My prices on bids...Someones gotta pay
these bills :)
Rob Teed 74 Painted Desert Lansing,Mi
I can't ever remember ever shimming anything. I believe the the hydraulic
lifter take care of the small deviation? In addition the although the
valvetrain is non adjustable that in my opinion is a good feature. I just
replaced all of the rockers on my 455 this spring and they only cost $16 a
side. Weren't that badly worn ofr 73,000 miles.
> aware of this....
> left for Beer!
> these bills :)
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Chuck:
When I tried the below URL, here's what I got:
Not Found
The requested URL /users/thall/olds/othed.htmllheads was not found on
this server.
Got a better URL?
Paul Bartz
- -----Original Message-----
Sent: Monday, November 16, 1998 10:03 PM
To: rodteed; gmcmotorhome
Subject: GMC: heads
go to www.en.com/users/thall/olds/othed.htmllheads This should give you
all you want to know about your olds engine. Where to look what to see
etc. chuck
here is the correct url
http://www.en.com/users/thall/olds/oldsfaq.htm
>Chuck:
>Not Found
>this server.
>Got a better URL?
> Paul Bartz
>From: Chuck Will [mailto:willa]
>Subject: GMC: heads
>etc. chuck
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
The last two pages were a little lolng but I did not know what else to do
since the www thing did not work for you. Chuck
> >Chuck:
> >Not Found
> >this server.
> >Got a better URL?
> > Paul Bartz
> >Subject: GMC: heads
> >etc. chuck
> Tom & Marg Warner
> Vernon Center NY
> 1976 palmbeach
