Jim
Tires:
I bought Goodyear Workhorse "E" 16.5
x8.75 tires about 2 years ago. I now
have
27000+ miles on them. I estimate that 1/2 the tread is still left. They have
been great tires - no trouble and the price was right. Goodyear store
charged me $600 flat for 6. That included mount, bal, and all taxes. I also
noticed that WalMart carries them at superstores. They are now about $95
each - special order. Many walmarts will now mount RV tires.
Headliner:
We did our own about 18 mos ago. Total cost was about $250. Plus that
included new sides (ie around windows). It took us a long weekend and we had
never done it before.
Remove all hanging cabinets. Big modules stay put.
Remove AC covers, ribs, fan covers, etc.
Remove old headliner carefully as you will use it as template.
Remove window trim and upper side panels carefully (templates).
All materials at Home Depot:
Insullation: Alum sided bubble insulation in rolls ($60)
Roof panels: Thermaply 4x8 sheets alum backed (6 @ $9 ea)
Side panels: Vinyl covered 1/8 plywood. 4x8 sheets. (4 @ $15 ea)
Contact cement (Heavy duty exterior) (2 gal @ $25 ea)
Finish material: Light weight indoor/outdoor carpet ($0.45/sqft)
We reinsulated roof and side with bubble insulation & alum tape.
We then covered the ThermaPly with a very short nap indoor/outdoor light
weight carpet. Heavy duty exterior contact cement to glue carpet to
thermaply. Cut panel to basic size using old panels as templates. Glued
carpet to panels prior to cutting to exact size. Gave better finish.
Also, instead of cutting the side panels in lots of small pieces like GM did
to save material, we cut full sheets for one piece. Looks much better.
All went really smooth and the end result with all the extra insullation
values made for a quieter ride and cooler coach in summer.
Some pics at
http://www.songtek.com/gmc/
Hope that helps
Mike F
- -----Original Message-----
[mailto
wner-gmcmotorhome]On Behalf Of jim white
Sent: Thursday, July 22, 1999 6:12 PM
To: gmc
Subject: GMC: headliner and tires
hate to keep bugging ...but need info on headliner and thought finding 16.5
e rated tires would be easy....little did i know.....has anyone found a
steel 16 inch....gm dually wheel works but have to go to larger studs,
anyone done that? alcoa's are back ordered 6mo. and i need tires.....
