Header Gaskets
> Here's an interesting link I stumbled across:
> Which header gasket should I buy? (summitracing.com)
> Ken H.
Ken,
The link is missing, I was going to try to replace it, but doing a search on Summit lead me to two different parts:
MS15141 at 15.99 is a roll pert core and punched with the tooling I had a McCord over 20 years ago. It was not a very good part. I tried to market a
better one but was shot down when I proposed it because there was not the market volume to justify the new tooling required.
21211 at 1,579.00 Is probably a mistake. By the description, it is a multi-layer stainless.
So, I can't be any more help than that.
Let's try again:
https://help.summitracing.com/app/answers/detail/a_id/4756/kw/which%20header%20gasket%20should%20I%20buy
If that doesn't work, or gets converted, enter the question shown into the
search box.
> > Ken H.
> Ken,
> Matt
> GMCES
